yep, I'm keen.
Definitely have to make it the Leicester or the Coopers Alehouse .... parking would probably be better at the Alehouse on a Saturday arvo? Last I remember the Leicester carpark wasn't that big .... the schnitzels at both certainly are though!!! :no:
  • Replies 280
Posted Images
Ok just a quick update for those who are wondering. I've contacted all three places and am awaiting their response. I will be PM'ing everyone with details of each place & what they are voting for within the next couple of days, so keep an eye on ur mail.
After the location of the meal is soughted out. Then it will be time to start planning the cruise. This may require a bit of input as far as roads are concerned & how far people want to travel, but first we will require a general direction people want to go (Specific suggestions of roads by PM only please). Anyhow more info will come to hand in the next few days.
Please note that I will not be posting up on here any of the final details so if you have not put your name down & are interested please either post ur interest or preferably PM me.
Cheers
don't know if my car is up for a cruise :whistling: starting to blow a bit of smoke on boost going to see Adelaide Turbo Services this friday so will see about the cruise, but i'm all up for a feed and a yarn :3some:
Also, not sure if i will take my car now, but on the other hand i can have a few bevo's and relax ....... if i can score a ride with someone "Dynoqueen" cough cough :)
Is that a hint there... :D too funny.
I will let you know if i am going once the details have been sent out.
a while back on a cruise to the whispering wall, it was thought to be a good idea to take pic of members next to their cars. maybe this would be a good idea on this occassion since so many new faces are coming onto the forum.
Im keen if its still ok to join.
Stock 32 4dr but still would like to meet some of you guys finally.
And a cruise would be great. Nothing massive as im still getting the hang of my car.
how much did you pay for the work wheels? they look awesome and are some of my fav wheels, look very tough and look forward to seeing them on the cruise!
i would like to go but i dont know anyone on this forum so i think i might give it a miss, plus im a p plater and cant drink any beers :) hope it al goes wel tho :)
Come on...... thats the whole idea to come and meet people from here, Bring a friend with you if you feel uncomfortable, Oh and they do sell soft drink there!
this is a good idea
hey, im back from a long time in the shadows, car is finally running smooth (fingers crossed) would be good to work out who's who and all.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
