Sorry for not replying sooner with your fasts guys but i cant attach pics at the moment because of a few bugs etc from the move to the new server.
Admins said it should be sorted out soon (in the next few days) then i will be able to post em up for you guys
6U9000BNR32220816
Can some please fast this?
Also I have the engine number, 029655A can this be checked through fast to see if it was the engine the car left teh factory with?
Cheers
Bobby
here ya go
hey sorry to be a pain in the ass but it says error with my one??
Its one of the problems that has been occurring since the move to the new server.
They are working on it but here it is again for you.
Enjoy
thanks for help guys appreciate it. quik question is there a link or somethin where i can see what the codes meeen in the vin number paint code build number etc...
to find out what your paint code means go here
http://www.skylinesaustralia.com/forums/Ni...es-t138419.html
Use this link to decode your model code except for the last letters (L,M,Z and G) which i posted the info for below.
Also has info on Car's Build Numbers.
http://www.users.on.net/~goofyhsk/info/chassis_plate.html
I have been doing a lot of searching around on the forums for the answer to what the last letters mean on the model codes for the early model r32 GTR's (L,M,Z and G).
cameronbnr32 and garrysandy the only info i could find for you guys (and any one else wondering) was a post from funkymonkey back in 2004.
From what i read the letters L and M, which occupy Positions 8 + 9 in the model code, are known as VS Sign (VS Options)...
L means it has Projector Headlights
M means it has both climate comtrol + upgraded stereo
Letters Z and G occupy Positions 10 + 11 in the model code and are known as Pack Sign (Package Extras Sign)...
Z Im still not sure what it means but some guys believe it might be to do with the interior trim. RellikZephyr Thought Z = Black Interior Trim.
Cant be confirmed unless funkymonkey or someone else knows for sure what it means.
G from what i found means ABS and a Viscous LSD
Hope that helps a lil for you guys wanting to know.
Below is funkymonkey's original post from back in the day
QUOTE(funkymonkey @ 23 Jun 2004, 01:56 AM)
Here's the factory Extras that are indicated by the last 7 characters ona 1989 -1991 R32
VS Sign
Position 1
Blank = Standard Headlight
L = Projector Headlight
Position 2
Blank = Standard
P = Electronic control active Full auto air-conditioner (Climate control system I assume)
Q = Electronic control active Sound System (Upgraded Sound System?)
Z = Cold District Specification
M = P +Q
V = P + Z
W = Q + Z
T = P + Q + Z
Pack Sign
CODE
Char Pos: 1 2
A Standard Standard
B 4 Wheel Anti Skid (ABS?) GTR Steering Wheel
C Sunroof Type M Specification
D GT Auto Spoiler (Front Only) Viscous LSD
E GT Auto Spoiler (Front and Rear) B + D
F B + C
G B + D
H B + E
I C + D
J C + E GTE Special Seat
K B + C + D J + Viscous LSD
L B + C + E
SS V Selection
CODE
Position Number: 0 1 2 3 4
1 With ASCD - RB20E RB20DE
Super HICAS RB20DET 2WD S Y Y
1 Audioless (All Cars) S Y Y
2 185/70 tyres + 14 inch rims (CA18i) S Y
2 15 Inch Alloy Rims S Y
3 Electric Side Mirrors (CA18i) S Y
3 Fender Mirror (All Cars) S Y Y
3 Rear Wiper S Y Y
S = Standard (ie. does not apply) Y = Vehicle is equipped with this
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
