Hmm? Thats weird cos I defintely dont have 2WD and an RB25DET. It is a 4WD with an RB26DETT??
Double check the vin numbe, or maybe i need to enter the r33 gtr bit proerply, are they known as anything else than the BCNR33?
Edited by Moodles2
can someone hook me up with a copy of fast. i had it on my old pc, but can't find the disks anymore since moving a while back. it would be much appreciated. ;) pm me if you can help out.
VIN number is spot on. Its an R33 GTR, hence BCNR33. All R33 GTSTs are ECNR33 so you have entered mine as an R33 GTST.
When I enter it as a BCNR33 and 005417 as the vin, I get this error from FAST, I;ve had this happen before but with a R32 GTR same error:
"MODEL SERIES CAN NOT BE FOUND FOR THIS VIN NO, INPUT MODEL OR MODEL SERIES"
All I can get is the production year which is: April 1995
strange. Its meant to be a 96 series 2?? Thanks anyway.
I've found a direct http mirror of Nissan FAST, I did a quick check on and it seems to be the same version as my earlier post. http://www.bidonville.net/.tmp/.nissan_fast/?C=M;O=D
Hi There
Can you please help. I am looking a buying a R32 GTR V Spec, It looks like I have found one. It has all the V Spec options, but i would like to confirm.
Here are the VIN Details
Chassis # BNR32-302103
Model # KBNR32RBFS AA
KH2 G
FS5R30A RC 41
I spoke to Nissan, they couldn't confirm it was a V Spec. They did say it was not a normal GTR it is a GTR.17 special model
Thanks
Hi There
KH2 G
FS5R30A RC 41
Thanks
My GTR is just a normal GTR and my model is KBNR32RXFS7, the 7 on the end means it's a normal GTR, if it was an 8 it means it's a V-Spec II, if the number is absent, it's a V-Spec I.
Also the KBNR32RBFS, B means it has 17" V-Spec wheels.
http://www.users.on.net/~goofyhsk/info/chassis_plate.html
Hi There
KH2 G
FS5R30A RC 41
Thanks
Edited by Moodles2
(I hope I entered it right)
Something strange is happening, whenever I click my uploaded screenshots I get "Sorry, an error occurred. If you are unsure on how to use a feature, or don't know why you got this error message, try looking through the help files for more information."
Hi Guys
Can someone please check A31 Cefiro ECA31 000083
Regards
Edited by Moodles2
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
