Hi, could someone check this VIN for me? My Fast cannot pull it up... I'm about to buy this car. Thx alot
This is for Vspec2Nur (The seller Claim it to be)...
Chassis: BNR34-400956
Vin #: GGJPRWYR34ZZAAGZ80
Doesnt come up on mine as well, model code indicates it is a Vspec (not sure what version), made in Feb 2001. I thought the NUR version was 2002 ? More qu's need to be asked I suspect.
Mine also doesnt come up on 2008 Jap FAST as well, as i suspect some are deleted from Nissan's database when they are exported.
How about this one
BNR34-403508
again nothing, sorry :D
however i did find out that with 34 GTR's my last recorded vin is
BNR34 - 402137 and anything bigger than that number is not on there.
that vin shows manufacture in July 2001 so i'm guessing the version i have has not been updated since...
Hey..
Not sure if you need any more details but Could you please do this one for me.
rb25 163672a
Cheers
Not sure what those numbers are, check your vin number and it should read something like 6U9000ECR33012345, what i need to do check it is this part of the vin 6U9000ECR33012345
check it out and let me know what it is, ill check it out asap ;)
Use this link to decode your model code
http://www.users.on.net/~goofyhsk/info/chassis_plate.html
It will help you decode everything except the last 4 letters, L, M, Z, G. The following is what i wrote back on page 39 of this thread about 10 posts down if you want to see my entire post.
I have been doing a lot of searching around on the forums for the answer to what the last letters mean on the model codes for the early model r32 GTR's (L,M,Z and G).
cameronbnr32 and garrysandy the only info i could find for you guys (and any one else wondering) was a post from funkymonkey back in 2004.
From what i read the letters L and M, which occupy Positions 8 + 9 in the model code, are known as VS Sign (VS Options)...
L means it has Projector Headlights
M means it has both climate comtrol + upgraded stereo
Letters Z and G occupy Positions 10 + 11 in the model code and are known as Pack Sign (Package Extras Sign)...
Z Im still not sure what it means but some guys believe it might be to do with the interior trim. RellikZephyr Thought Z = Black Interior Trim.
Cant be confirmed unless funkymonkey or someone else knows for sure what it means.
G from what i found means ABS and a Viscous LSD
Hope that helps a lil.
Was this ever expanded upon? My car has one of those odd model codes.
KBNR32RXFSLMZG
Strangely this gives a build date of 6/90 rather than the FAST 10/89 for my chassis BNR32002505:
http://fteqw.com/moodles/model-decoder.php...amp;chassis_no=
This doesn't give all the answers either. So weird. :)
KBNR32RXFSLMZG
As far as i know there is no date information in the Model Code, so 10/89 it is.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
