Cold region package is heated mirrors etc.
Hi (00)Skyline(00),
I think Miguelone is correct with the mirrors.
The car has heated seats too. I'll try to upload some pics but I'm a bit of a noob in that regard.
I see, it would defiantly come in handy for the winter.
Sounds good :)
Ok, so i have done a revs check on this car and its showing it was complied in 05/1990 and that its a vspec?
V spec were made 93?
Anyone know whats the deal here?
Yes, V-Spec's were made in 1993.
Post the Model Number and let me have a look.
It's the number starting with "KBNR32..." Under the Chassis Number on the blue plate.
BNR32-008320
KBNR32RXFSLTAA
Im not sure why its showing the compliance date as the build date also, through the revs check?
REVS is wrong.
Compliance Date can not equal the build date... That's impossible as it was built in 05 - 1990 and only just came to AUS.
Compliance Date usually refers to when the car was complied to AUS Standards / ADR Laws.
Your model number checks out to be a Base Model R32 GTR, made in 05 - May.
KBNR32RXFSLTAA - "X" signifies it is a GTR (16 Inch Wheels) = Base Model.
If the "X" was a "B" then it would = V-Spec (17 Inch Wheels)
On a side note: KBNR32RXFSLTAA, "L" = Fog Lights from factory... You have fog lights on the car?
Is this genuine V-Spec?
Vin-BNR32-302657 (Chassis No)
Model-KBNR32RBFS AA
These numbers are on the Blue Compliance plate from Japan I believe.
Thanks in advance.
Edited by glaze
BNR32-008320
KBNR32RXFSLTAA
Someone messed up when they did the registration. See it on imports a lot. Either build date is compliance date or compliance date is build date lol.
Model-KBNR32RBFS AA
Thanks in advance.
Anypne help me out with this? I have done some more research and I am 99% sure it is a VSpec, but just want it confirmed:) Thx
Model-KBNR32RBFS AA
Thanks in advance.
Vin- 6U9000BNR32302657
Eng-RB26 078615A
Yeah, the VIN and Model Number it checks out to be a V-Spec:
Sweet! Thx (00)SKYLINE(00). Put a deposit on this tonight and will have in my hands next weekend.
Sounds good, post some pics :)
Visibly you should be able to tell in stock form:
Brembo Front and Rear Calipers.
17 x 7 +20 or 17 x 8 +30 BBS Wheels (Check the centre of the wheels)
V-Spec Sticker on the boot lid.
A retuned ATTESA E-TS system but that you wouldn't be able to tell straight up.
It doesn't come with Rear Brembo's unfortunately or stock wheels. Will start the search for these ASAP;)
Interesting... So it's got stock Brembos on the front but not on the rears...
So what's on the rears? Just "Nissan" (Sumitomo) calipers?
  • 3 weeks later...
Can someone please check
BNR34-001021
Thanks in advance!
Is it possible to get late KV36 model checked which doesnt come up in FAST system. KV36-400752
Thanks in advance
I am getting mix of 5 results but all the listings say the build date is December 2008...
Thanks Mate,
Does it show what factory options it has and all like the FAST system or just the build date? Build date of Dec 2008 sounds right.
Edited by rawzz_v35
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
