Thanks Mate,
Does it show what factory options it has and all like the FAST system or just the build date? Build date of Dec 2008 sounds right.
Can't say it does...
That's the only difference the system is picking up, which is the different Drivetrain and Grade of car.
Thank you.. even though I cant see the 2nd attachment..
Still no.. maybe its my browser.. anyway i assume it doesnt say much more than the other one...
Thanks heaps :)
It just list the Drivetrains and Grades:
2WD/STD - 370GTS
2WD/STD - 370GTP
2WD/STD - 370GTSP
2WD/4WAS - 370GTS
2WD/4WAS - 370GTSP
So not much but at least you get the info :)
Thanks heaps. Any idea why it gives out different drivetrains and grades... it should be 2WD/STD - 370GTSP as per the car i have... :)
Because the FAST catalogues on epc-data don't know what your car is. It knows as much as it being a V36 then it shows a list of relevant applicable models without providing specific information. I tried with my 09 catalogues but I'm getting a CD Player Error which happens when data is missing. These are issues you run into when running software not officially provided or updated by the manufacturer.
  • Like 1
This +1
Hi can someone do my car
bnr32002721
also have been told it has a r34 motor can this be checked from the engine no.? It is rb26037663A
thanks
what is the newer version of fast everyone is using, also
rs13-611755
does that vin work for anyone, if so what version of fast are you using as its not working on my version, and i know it corrects
There were complications with that VIN but it was narrowed down to 2 results.
RS13
Hatchback
CA18DET
2WS (No Super HICAS)
Built: Jan, 1990
Grade: Type 1
Manual
Only difference with the other result was it saying Automatic for the transmission.
  • Like 1
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
