  • 4 weeks later...
  • 1 month later...
On 09/01/2017 at 7:46 AM, RANDY said:
Hi, I was wondering if anyone could check Fast to search for both left and right lower control arms on a R32 GTR? I have a 1993 model, series 2.
I'm having issues with these arms. I purchased a replacement for my suspected bent one but I don't think it is the right one and the number stamped on it is different. I tried contacting Nissan but was told Fast no longer has R32's loaded. I'm getting desperate and don't want to buy another until I know what the issue is.
Do you need my VIN?
Thanks in advance
Cheers
Do you need my VIN?
Thanks in advance
Cheers
Probably the most accurate way, but here are all the part numbers. A late R32 is what I selected:
13 hours ago, RANDY said:
It looks like the part changed in 93, so VIN would show only one part.
Hey, thanks Randy. My VIN is BNR32-301183 . The arms on my car have H2405U (Left) marked in the casting. 5H05U (Right). The right one seems to be the problem and increases neg camber more than left.
I fitted another right arm marked 3405U and drastically reduced camber to zero. I'm pretty sure the left one is correct and camber is where it should be. Only things it could be is the 3rd link or maybe the cross member? Car has no signs of major damage that's been repaired so I'm thinking the original arm is bent and I need a replacement 5H05U.
Thanks again for the quick reply mate.
Double post!
No probs! Cheers!
Presumably you don't have camber bolts in the struts?
Here are the part numbers for your car, and the alternate part numbers. The other side is 54505 with the same endings.
-Steve
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
