On 13/01/2017 at 4:22 PM, RANDY said:
No probs! Cheers!
Presumably you don't have camber bolts in the struts?
Here are the part numbers for your car, and the alternate part numbers. The other side is 54505 with the same endings.
-Steve
Thanks Steve for your help. Based on the markings on the LCA's I have, is there anyway to know which is the correct ones?
Also I have noticed the inner and outer ball joints have markings and most likely a certain direction they need to be fitted. The service manual does not tell me much. Any further info in FAST? The outer ball joint has the following markings, 8 7 or L and R. I bet the bloody ball joints are around the wrong way. This would explain the difference in camber. I will check R faces the right side of the car. There are markings on the inner ball joint too. I has the letter B and the other the letter A. No idea what that is all about. I will remove both LCA's soon and double check orientation.
Also, can you tell me the part number for HICAS steering rear rack end for my car? BNR32-301183
Cheers Peter
Edited by my_gtr32
Cheers Peter
Hey mate, i'm not sure on what sort of markings are on the parts, but if they look identical from left to right and they measure up the same, it's probably fine. I'm not sure about ball joint direction, other than one is for the left and other for the right. Do you have camber bolts?
Not sure if i've found the part you want:
Hi, no the part you looked for is not the right one. I need the tie rod shaft. 48521 is the first bit of the part number. What is the full part number?
I don't have camber bolts but have adjustable upper arms. When I purchased the car the right front wheel always needed the upper arm to be 10mm longer than left to match camber. This screws up caster and ride height. I changed the right arm and now I only have 0.5 degree camber on the right where before it would have been over 2 degrees. That is a huge change so a little variation of the LCA length (from ball joint to ball joint), makes a big difference to camber It measures 315mm on a GTR LCA.
Standard upper arms are 178mm long on a R32 GTR, so if you lower the car to 350mm from hub centre the camber will increase to 1.4 degrees or so. With the right LCA marked 3405U, camber is 0 degree. I have it adjusted as short as possible which is 175mm and I get 0.5 degree instead of almost 2 which you would expect.
I have never heard of any direction the ball joints need to be installed either but why is there markings on them and mention in the service manual that many do go in a certain way. A few millimetres difference in the length of the LCA is all that it takes to resolve the issue. I either have another bent arm (unlikely) or it simply isn't the correct part for a late model R32. All I have to go by is the numbers stamped in the arms. I need to match these numbers with the part numbers you have given me. Nightmare.
Cheers
Cheers
yeah wow. What a mess! Good luck with that I suppose!?
44 minutes ago, Giaccovitch said:
Hi could anybody match mine,
BNR32-005619
Engine no. 004051 A
My FAST won't look that up for some reason, but it does show on http://gtr-registry.com/en-bnr32-vin-table.php just chuck the 6 digits in the search box on the right. =-]
Fixed it.
Cheers mate, is there any way to see what car my engine is from?
mmm... as in: is it an R33 engine or something... my bro-in-law has that scenario and I think stuff like the oil pump is different and a few other obscure things. I'll have a dig around.
Yeah not sure what engine it is
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
