On 13/01/2017 at 4:22 PM, RANDY said:
No probs! Cheers!
Presumably you don't have camber bolts in the struts?
Here are the part numbers for your car, and the alternate part numbers. The other side is 54505 with the same endings.
-Steve
Thanks Steve for your help. Based on the markings on the LCA's I have, is there anyway to know which is the correct ones?
Also I have noticed the inner and outer ball joints have markings and most likely a certain direction they need to be fitted. The service manual does not tell me much. Any further info in FAST? The outer ball joint has the following markings, 8 7 or L and R. I bet the bloody ball joints are around the wrong way. This would explain the difference in camber. I will check R faces the right side of the car. There are markings on the inner ball joint too. I has the letter B and the other the letter A. No idea what that is all about. I will remove both LCA's soon and double check orientation.
Also, can you tell me the part number for HICAS steering rear rack end for my car? BNR32-301183
Cheers Peter
Edited by my_gtr32
Cheers Peter
Hey mate, i'm not sure on what sort of markings are on the parts, but if they look identical from left to right and they measure up the same, it's probably fine. I'm not sure about ball joint direction, other than one is for the left and other for the right. Do you have camber bolts?
Not sure if i've found the part you want:
Hi, no the part you looked for is not the right one. I need the tie rod shaft. 48521 is the first bit of the part number. What is the full part number?
I don't have camber bolts but have adjustable upper arms. When I purchased the car the right front wheel always needed the upper arm to be 10mm longer than left to match camber. This screws up caster and ride height. I changed the right arm and now I only have 0.5 degree camber on the right where before it would have been over 2 degrees. That is a huge change so a little variation of the LCA length (from ball joint to ball joint), makes a big difference to camber It measures 315mm on a GTR LCA.
Standard upper arms are 178mm long on a R32 GTR, so if you lower the car to 350mm from hub centre the camber will increase to 1.4 degrees or so. With the right LCA marked 3405U, camber is 0 degree. I have it adjusted as short as possible which is 175mm and I get 0.5 degree instead of almost 2 which you would expect.
I have never heard of any direction the ball joints need to be installed either but why is there markings on them and mention in the service manual that many do go in a certain way. A few millimetres difference in the length of the LCA is all that it takes to resolve the issue. I either have another bent arm (unlikely) or it simply isn't the correct part for a late model R32. All I have to go by is the numbers stamped in the arms. I need to match these numbers with the part numbers you have given me. Nightmare.
Cheers
Cheers
yeah wow. What a mess! Good luck with that I suppose!?
44 minutes ago, Giaccovitch said:
Hi could anybody match mine,
BNR32-005619
Engine no. 004051 A
My FAST won't look that up for some reason, but it does show on http://gtr-registry.com/en-bnr32-vin-table.php just chuck the 6 digits in the search box on the right. =-]
Fixed it.
Cheers mate, is there any way to see what car my engine is from?
mmm... as in: is it an R33 engine or something... my bro-in-law has that scenario and I think stuff like the oil pump is different and a few other obscure things. I'll have a dig around.
Yeah not sure what engine it is
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
