  • 3 weeks later...
CeJay, if the R33 standards fit, then mine should be right for you as well. I'm waiting on when Jarrod needs them, but if they are right for you and are not at the same time as Jarrod needing them, shouldn't be an issue.
  • 2 months later...
Hey guys,
I'm looking to swap my coilpacks for some Splitfires just for a day. I got a tune today and fell 4psi short of what I was going to run due to misfire. I wanna get the next tune out of the way quick and then not drive the car much after so if someone has some Splitfires that we could do a quick swap with that should be great. Its an R32gts-t so RB25 series 1's and RB26 coils will be fine.
Cheers,
Adrian
  • 4 weeks later...
  • 1 month later...
Hey,
unfortunately i was lucky enough to get defected before chirstmas :D
I was wondering if anybody had any stock R33 GTR Coilovers and stock GTR rims that i could borrow for a couple of days to get it passed Rego?
Cheers,
Mick
  • 4 months later...
  • 1 month later...
Hi all,
Bought my first skyline on Monday, i decided to get the stock wheels instead of the 19inch ones one the car. buuut they dont have enough tread to pass an inspection for rego. so does anyone have some street legal/stock r33 gtst wheels with decent rubber on them OR some rubber to fit 205/55/r16 that i could buy?
the inspection is this Friday (23rd) so its kinda urgent =/
thanks
Edited by GDC
  • 3 weeks later...
Hi all,
I'm doing an engineering project on looking into the heat dispersion in R33 GTS-T brake calipers using thermal imaging. This will involve me doing testing on the brake calipers in a lab then comparing them against the brake calipers in my R33 GTS-T.
To do this though, I'm needing to get standard 4 pot and 2 pot front and rear brake calipers. Does anybody have these for an R33 GTS-T that they are willing to let me borrow for the next few months? I only need one of each and won't damage them in testing. I'm also willing to pay to be able to borrow them.
This will save me having to spend a huge amount of money, so if anybody could help me out, I would be deeply thankful.
Thanks,
MJ.
(with any luck) as of Friday the 27th I will have the following available to lend people for testing purposes:
R33 GTS-T series 1 ECU
R33 GTS-T series 1 AFM
R33 GTS-T series 1 coilpacks (5/6 are JJR coilpacks, 1/6 is standard)
R33 GTS-T series 1 injectors
  • 2 months later...
hey hey... :(
can anyone lend me r32 stock suspension... and handbrake lever only (without drift button)
i have
-set of r32 rims
-set of s14/33 rims
-set of XR8 rims (AU)
-standard intercooler and piping for r32
-front reo bar for r32
-brand new set of rear cradle bushes any nissan(for sale)
any help would be GREAT!!! :)
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
