  • 4 weeks later...
Has anyone got a stock exhaust for an R32 GTS-T I can borrow. I have an inspection with dickson on Friday, so If I could pick up tomorrow night that would be fantastic.
I have a diff back exhaust that will pass Dickson. It will fit R32s with a 3" or 3.5" exhaust
Also i am looking for a set of R32 GTR wheels to borrow for Dickson
When is your inspection. I have a set of r33 gtr wheels, that will be getting new tyres soon. I'm borrowing a friends 34 gtt wheels.
Ill pm you regarding the exhaust.
Anyone able to lend me a compression tester that I can borrow?
Ok, i got one.
Cat back pipe with a peashooter, if you want to use it. Even got a stock downpipe if you need it.
And other things.....
  • 3 weeks later...
  • 1 month later...
Has any got some 18" Wheels to suit a GTR with 245/40 tyres that I could borrow for a rego inspection? I can lend you mine so your car is not unmovable?
I need new tyres but I wanna go 255, unfortunately my engineer cert is for 245s though
Anyone have an RB25 turbo I can borrow for a few days. Need to get mine sent for update to Hypergear. Just need it to install in car and drive it out of the shed whilst mine is going away. Will not drive more than 20m with your turbo.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
