  • Replies 422
Posted Images
My coils have decided to go kaput.
Hopefully I get them in time, previous parts I order from nengun took 1month. :S
If I need to step aside due to reaching the target I have no problems doing so. If so I will still be there. :)
Sorry guys, gonna have to pull out, I just went to pay and remembered that my 21st is on the same day. Got preparation and stuff like that in the morning to get ready for the big night. I'll definitely be keen for the next one though
If I need to step aside due to reaching the target I have no problems doing so. If so I will still be there. :rolleyes:
If you need some to tide you over you're welcome to use my spares.
You've got my number so feel free to give me a buzz.
Thanks to Madaz and Lee for the deposits.
Who is Stuart ? Whats your SAU nick?
A quick update.
3. gtrGhosTDoGG11 paid
8. Nightcrawler paid
16. Madaz paid
23. Lee paid
Only 5 people have paid a deposit. Could you please leave a deposit asap.
Edited by gtrGhosTDoGG11
Sure can! :) PM me with the details
cheers mate :PBJ:
A quick update.
16. Madaz paid
23. Lee paid
Hi Will (?),
I'm fairly sure I PM'd you a few day ago with... 'count me in' - maybe it didn't make it? I'll be there on the day and I daresay my car will still be at the workshop. If the car is ready then I'll put it on the dyno.
If you like (and don't mind?) I can pay Shaun tomorrow when I'm at the workshop.
Cheers,
Matt
Hi Will (?),
Cheers,
Matt
Hi Matt,
Soz, must of missed that pm. I'd rather you dont pay him as it might cause some confusion on the day and cause extra hassle for him. I'll add you on the list and pm u with deposit details so you can do it online.
thirtyfour - ive added you on da list, and pm'd u
Can i grab a pm of the details please, i think it's about time that i paid the deposit :D Now that i read the thread correctly and realised its in September! lol
Edited by DC_GTST
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
