Looks very much like it will be around the Adelaide area....
ah ok thats my neck of the woods :)
after going back and looking @ your car on first looks its OMG very nice but a lot of it is just shinny bling you could possibly get it passed dont quote me on that but yeah iven if you had to return a few things back to get it complied for this state once complied you could pretty much return it as it is now and not get too much grief over it
I'm not 100% sure as its how I bought it. They definately fit fine though, completely flush and pretty sure they are genuine ganador mirrors as they were on the vehicle from japan.
EDIT
Yep! attached is pic of original ganador mirrors
Edited by Hotwire
17x9.5' A-Tech rims with 245/45 rubber. Would look better with some cross drilled brakes behind them :P
Without the silencer, the 3.5" Kakimoto exhaust is louder than a Mack truck!! (and talk about drone central)
Nismo front pipes and hi flow cat help too :)
Polish bay that could look better with a bit of a clean
All taken on Canon 1-D mk3, with either 70-200 f/2.8L USM, 28-70 f/2.8L USM or 16-35mm f/2.8L USM.
Cheers
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
