Yeah you sure showed him. You're not doing yourself any favors... if that cop see's you driving around again he'll probably make it his business to pull you over. At the end of the day, you're just digging your own grave being a smartass to cops. I can understand the urge to do it to the ones that are being unreasonable but you just have to bite your tongue...
why should i ?
he's messed up my life and im not going to go into any details on here because it has nothing to do with you or anyone else.
your entitled to your own opinion by all means.
+1
I have had a habbit in the past of giving cops shit when ever they fine me, apart from when i lived in moe (small country town) this has never come back to bite me, i do the same as they do, i gauge how they are going to be with me and act accordingly, if they are going to be robo cop and at like a flamin mongrel then so will i, even had one call me a flamin mongrel, arsehole, top bloke, cock sucker and every other one you can think of because i asked him for the calibration sheet for the in car speedo that he used to record my alleged speed, went past that spot every night at the same time for 12 months after that and never saw him again.
+1
nailed it.
because if he hadnt have gone off at the cop they would have just cruised on by when they saw him out in his bright orange skyline.. yeh right.. do whatever you want your gonna get reemed anyway
it was at a station AFTER he had defected me . learn to read.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
