Here are a few before + after shots of my R33 gtst. I recently fitted stock bodykit and smaller, less flashy 18" wheels as I'm now using it as a daily (and I was cringing every time I bottomed out :thumbsup: )
Before:
After:
I am currently selling the 19" wheels, explosion bodykit and cannon muffler, if interested check out the links! :)
http://www.skylinesaustralia.com/forums/Fu...dy-t313973.html
http://www.skylinesaustralia.com/forums/19...yr-t315662.html
Edited by bt23
post-7531-1157971103.jpgpost-7531-1157970955.jpgpost-7531-1157970807.jpgpost-7531-1157970593.jpgthis is before the air brushing i am sure everyone has seen it just fitting in with the post so save your comments if you reply is gonna be we have seen it before ?
What are these rims called been trying to trace them down, they gotta look better than my advanti stalkers.
page 6, the black rig it didn't quote properly :(
Edited by 3340TH
Collen, I don't need to tell you how good the car looks, I've told you that enough! But fkn hell your photography is awesome!! Fantastic work mate.
SLYDA, that's the first time i've seen a Bomex kit look good on an R33.
Thanks :)... a LOT of work went into that to make it look how i wanted.. couldnt bring myself too put the series 1 bomex kit on it, and no one had a decent series 2 either (plus near impossible to find)... so it was time to cut up a R34 kit and make it fit, not as easy as i thought..
thanks mate! i took about 100 pics and came up with these 3 or 4 from that night. if you sit around playing with settings on the camera enough you eventually come u p with something.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
