Here are a few before + after shots of my R33 gtst. I recently fitted stock bodykit and smaller, less flashy 18" wheels as I'm now using it as a daily (and I was cringing every time I bottomed out :thumbsup: )
Before:
After:
I am currently selling the 19" wheels, explosion bodykit and cannon muffler, if interested check out the links! :)
http://www.skylinesaustralia.com/forums/Fu...dy-t313973.html
http://www.skylinesaustralia.com/forums/19...yr-t315662.html
Edited by bt23
post-7531-1157971103.jpgpost-7531-1157970955.jpgpost-7531-1157970807.jpgpost-7531-1157970593.jpgthis is before the air brushing i am sure everyone has seen it just fitting in with the post so save your comments if you reply is gonna be we have seen it before ?
What are these rims called been trying to trace them down, they gotta look better than my advanti stalkers.
page 6, the black rig it didn't quote properly :(
Edited by 3340TH
Collen, I don't need to tell you how good the car looks, I've told you that enough! But fkn hell your photography is awesome!! Fantastic work mate.
SLYDA, that's the first time i've seen a Bomex kit look good on an R33.
Thanks :)... a LOT of work went into that to make it look how i wanted.. couldnt bring myself too put the series 1 bomex kit on it, and no one had a decent series 2 either (plus near impossible to find)... so it was time to cut up a R34 kit and make it fit, not as easy as i thought..
thanks mate! i took about 100 pics and came up with these 3 or 4 from that night. if you sit around playing with settings on the camera enough you eventually come u p with something.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
