Here are a few before + after shots of my R33 gtst. I recently fitted stock bodykit and smaller, less flashy 18" wheels as I'm now using it as a daily (and I was cringing every time I bottomed out :thumbsup: )
Before:
After:
I am currently selling the 19" wheels, explosion bodykit and cannon muffler, if interested check out the links! :)
http://www.skylinesaustralia.com/forums/Fu...dy-t313973.html
http://www.skylinesaustralia.com/forums/19...yr-t315662.html
Edited by bt23
post-7531-1157971103.jpgpost-7531-1157970955.jpgpost-7531-1157970807.jpgpost-7531-1157970593.jpgthis is before the air brushing i am sure everyone has seen it just fitting in with the post so save your comments if you reply is gonna be we have seen it before ?
What are these rims called been trying to trace them down, they gotta look better than my advanti stalkers.
page 6, the black rig it didn't quote properly :(
Edited by 3340TH
Collen, I don't need to tell you how good the car looks, I've told you that enough! But fkn hell your photography is awesome!! Fantastic work mate.
SLYDA, that's the first time i've seen a Bomex kit look good on an R33.
Thanks :)... a LOT of work went into that to make it look how i wanted.. couldnt bring myself too put the series 1 bomex kit on it, and no one had a decent series 2 either (plus near impossible to find)... so it was time to cut up a R34 kit and make it fit, not as easy as i thought..
thanks mate! i took about 100 pics and came up with these 3 or 4 from that night. if you sit around playing with settings on the camera enough you eventually come u p with something.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
