What happened to your car Grant?
Nathan,
I may have killed something but won't know what exactly until I've have it looked by Trent of Status Tuning tomorrow or wednesday, look for my thread on Victoria forums for updates.
Cheers
Grant
What happened to your car that day? Saw you hammering around the track probably once, and then it looked like you were taking it easy? Did something break?
Can post up pics of your car if you want too.
Hey Mate,
Was on radials in the first 2 session bedding in some new pads which i decided to toss. Third session went out with the r-comps and ferodo's - whilst on this hot lap (passenger session) coming out of last turn - stripped 3rd gear - the temporary standard box could not cope with the torque - even after a detune the day before. :)
Cheers
Steve
Wow that sucks to hear mate. The car sounded like it was running sweet in the first few sessions. Car looks awesome and i hear its participating in superlap? I hope you go well and i will see you at Superlap if so!
Here's just one of many photos i took of your car on the day, i hope you enjoy it.
Thanks,
Kory
Prescott, those pics are from the Nasho down around sutherland yeah? Nice clean pics.
They're actually from a Putty road drive we did a couple of weeks ago.
Haven't driven Nasho yet :)
First pic makes me sad at fail wheel widths/offsets. Im thinking of getting the LMGT2's modified to be 1" wider and 1" less offset :P
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
