Very nice Pete! What coil overs did you get? I'm hanging out to get some myself, mine sits way too high at the moment. I'm thinking of going tein super street. Here is a few pics of mine. Still have a few little things to do to get it the way I want it. Cheers.
that looks sweet man. i was unsure at first how the gt-c's would look on a 33r, yours just backs up how awesome they fit.
you could say i cheaped out if you want but since i havent heard anything bad about them i thought id try the BC Racing ones from JustJap. got the ones with the external oil reservoirs so you can adjust the damper compression and rebound separately. we'll see how they go but for $1600 bucks i thought i had to try em. plus they come with a 12 month warranty too. ive just gotta set the rears up a little higher so they match the fronts and itll be sweet..
Thanks Pete, gtcs look awesome on gtrs and urs proves how much better it looks with it lowered. I was thinking about of bc racing suspension too. I first fell in love with the gtcs when I saw bakes black r34 with some gold 19" gtcs. Looked amazing ever since then I developed a fondness of that rim. I've seen 19s on r33 and they really look like pure sex. Ahhh if only they didn't require selling a few organs to get your hands on them, still I'm more than happy with the 18s and semi deep dish look! Cheers.
Yeah the 19s are really for bling factor, no added performance. I think its my ride height that makes my 18s small and can't fill the gaps, anyway here is a nice example of R33 with 19s. I think he had to do a bit of modding to the inner guards to get them to fit though, 19x10.5!
Ok so time I put GD2ILA up here. I've owned the car for 2.5 years.
Recently I made the front lip (in carbon), added Carbon rear wing and changed the wheels for some dish. I plan so start doing some more external cosmetics, but I'm really pleased with the way it's coming along.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
