Here is my kn6 1998 r33 GTR series 3 vspec
Looks brand new! Gorgeous!
+1 Granthem gorgeous car dude. Do you have any pics of the taillights lit up?
I'm thinking of grabbing a set just for the clear indicator part but dunno about the tail lights. Can't seem to find a pic anywhere with them on
I will try and take a photo of them and post it up. The light up pretty cool IMO, but the plastic is bad quality and fades to pink (as has happened to mine). Mine are the normal style lights (not LED), with LED bulks fitted in place of standard type. I got these wicked 36 bulb LEDs off ebay.
They are hard to capture in a photo but ill do my best!
Those are Prodrive GC-10 wheels 19x10 +18 offset w 275/30/19 Potenzas.
Not sure what the availability of Prodrive wheels is like in Australia. They are very uncommon here in sizes that would fit a GTR. Hold your breath for pricing.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
