believe i saw this parked down at the main strip of shops at lorne 2 weeks ago?
looks great
Yeah man that was me, went up to Appollo Bay for the weekend with the boys. Had heaps of fun weaving in out on the great ocean rd. What were you doing there?
Yeah they're the ones - It will look real good with the carbon surround you beat me into buying! haha
are they the border ones? had my eye on them for ages, they look great. ive got a carbon intercooler surround that would go great with em too
oh yeah and new tail lights
how day they look during the day??
would love to know the brand??
