black and polished always works best...thats why harleys always do it...its high maintenance but the results are worthy.. :thumbsup:
how clean is your undercariage, hose it down and soak all your suspensions in wd40, rinse and repeat till it looks clean, clean out your brakes..costs next to nothing and will get you respect points at the hoist as well..
nice work :). when i first read WD and brakes i was like :O, then i realised you didnt leave them on for the WDing.
need to paint my calipers before doing anything like that, i still have inner plastics in my wheel arches that i keep clean :)......till i rip them out on a bump.
hehe..i cleaned the calipers with brakecleen and hot water with some dishawashing liquid..dropped all the little parts in some aluminium wash stuff called aluplus or somtehing, its kind of like the stuff your grandma uses to clean brass and cutlery but more toxic, it actually stipped the coating off some of the bolts :nuke: ....cleaned the pads up with some hot water and a scourer...also pinched the scrubber brush from the kitchen sink, missus wasnt too happy about that
yeah thats usually how it starts hey, takes 2 hours to pull it all apart and 2 months to get it all back together again...
Hahaha..... Soooooooo true.
Oh and BTW I told you god knows how long ago polishing is for mugs :)
well i got my wheels polishes properly and they look mint, but just had a bottle of wheel polish next to me while i was putting the brakes together so i though id have a go...one bolt was as far as I got and i didnt even finish it .. >_<
but i tell ya wd40 is the shit..i have degreased under my car heaps of times with various products and got nothing but lacklustre results..discovered wd40 is only 7$ a can at bunnings and thats the big can, half the price of auto shops..I let loose 2 cans under my whole car and it looks like new..everything is shiny black instead of dusty brown..And it stays black even after it dries unlike the cheapy crap degreaser....
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
