Yea im not sure what it is about those rims Blags, but I cant help but stare at them whenever i see a set.
You guys are REALLY not helping me with my want for a black car lol :glare: Can we have a page where you all talk about how hard they are to keep clean? :P
if only it were true.......after seeing my white car, and Mumslayers black 32.....the white is harder to keep clean.
that help? :P and Bah, your silver is good!
Prehaps a little? :blush: haha
Well I mostly want a black one so i can blend a load of carbon fibre in :yes:
Nice one! What design are those wheels? Its got me intrigued. They kind of look like VS Andrew's???
Nope, it's Panasport G7 Flat spoke (there's curved spokes as well)
Very tidy, love those BBS wheels to. The engine bay looks nice and tidy, good work
Thanks mate! I LOVE BBS wheels and wish I can afford to put them on every single car I ever hope to own hahaha
What front bar turbodragon?!? It looks awesome.
Normally the nismo lip on the stock s2 front bar sticks out and is obviously an add-on, so it can't be that.
Yep, what Granthem said. It's a full Explosive kit (front bar, side skirt and rear half-bar). I used to have the Nismo front lip with the usual Spec-M skirts and rear pods but wanted something that looked almost factory without being over-the-top with vents everywhere :thumbsup:
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
