Nice looker there Kevin.
Been a while since I've put an update in here myself. Sorry that it's so dark, I can't seem to get everything done in time to take some pics during the decent light of day.
After sporting a "clean look" for about 5 years, I've decided to go for something a bit different. Some will like it, some will hate it. I know. But I really like it right now and that's what counts.
Thanks buddy!! I like your train of thought; it's your car so as long as you like it who cares what others think.
Your car looks nice and is still clean. It's not like you have Nismo stripes going across the body!!
Good work mate. Rims suit too!
They are actually Lenso Project-D spec E Concave Wheels.
I bought them from Budi at Autotechnica here on the Forums. They are a trader and are currently selling the 18 x 9.5 version in black for $1000 a set.
I bought my Lenso Dish wheels from Budi too. Great guy to deal with, I recommend highly.
I have these pics on Photobucket, but the site doesnt allow to link them. Any suggestions on photosharing websites that are allowed?
Photobucket works fine, use the image icon at the top when replying and paste the direct link there it will work.
for example.
Thanks a lot buddy. I was using the HTML link I think. Its been a long time since I jumped on a forum. Hehe.
Like he said :)
Car looks good man, nice stance.
Cheers bud! :cheers:
Nice car, Impul front bar :thumbsup:
Cheers! Bumper does look alright without being too ricey I think. LOL.
Car looks great mate!
Cheers bud :cheers:
That does look good. Best looking bar I've seen on a Series 2 yet!
Thanks mate :D
Easily the best. I wish I knew that front bar existed before I resprayed the stone chips out of my stock s2 front bar! Great car man. :)
The bar on mycar also has two small cracks, I would like to also get it resprayed as well as the rear bumper.
Unfortunately, the car is up for grabs now :(
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
