What size and offset are your rims on the gtst mate?
They were 18x9 +20 front and 18x10 +5 on the rear. Front and rear guards were standard all I did for the rears was roll the lip flat with the guard (not pumped at all) just to allow a tiny bit of suspension travel and that was it. Fronts actually had a 5mm spacer from memory
Edited by Weapon
A few quick pics of my 33. Also a video of my new varex exhaust for anyone interested.
Its almost complete in my eyes. It is stock height, stock wheels but I like it. I feel a lot more safe from police in this form.
As soon as my mate gets back from a week away, my new cat is being put in and some gauges wired up. All it needs now I think is a bit of a tune up. Only problem I have with the car really is the return to idle, it sometimes lopes as seen in the video but fortunately doesnt stall. Strangely it is a tiny bit laggier since installing the varex. A smaller air filter was installed at the same time. Will have to see which one is causing the problem.
Edited by Bennis
so gave the car a clean and had a play with the camera. the one thing i struggle with is framing a shot, so i drove around until i found a reasonably good place for photos. here are a couple of shots i took:
these were all taken using my 50mm SMC Super Takumar lens
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
