Waz; *politely* S-A-T-A-N-I-C ;) Cheers Bro!
666DAN; would've been more; just need a nice boost controller or someone who knows how to use the Hybrid EBC properly :) then I should be closer to Abo's number!
  • 1 month later...
thought i would list my mods since i have an auto r33
Hks frount mount intercooler
3inch turbo back exhaust with metal hi flow cat
GCG hi flow turbo 450hp
Greddy profec A boost controller
Apexi Safc 2
Apexi Sitc
Bosch 040 fuel pump
Sard Fuel regulator
hks cam gear (not currently installed)
Standard injectors
Z32 AFM
Stock transmission just with tranny cooler
Mv Auto Shift kit (in the process of buying)
I Have had the car for 4 years have considered converting to manual but i have alway's liked the auto. I got car tuned a couple of weeks ago and got 196kw at the wheels before i maxed out my stock AFM on 10.5 pounds. Last week bought a Z32 afm and retuned the car and made 229rwkw on 14psi. but now worried about the transmission since i have already blown one and don't want to kill another so i am hoping the shift kit should be able to cope with the power alright.
It is yet to be run will go to calder when the Mv valve body is in.
wife's daily driver..
s1 r33 4 door
rb25det
acl forged pistons
eagle rods
Jun crank collar
N1 oil pump
new nissan water pump
ARP main, big end, and head studs
full nissan gasket set including head gasket
standard head
standard plenum
standard coilpacks
stainless low mount manifold
gt3582r-iw
custom 3 inch dump
full 3 inch stainless system
ASE FMIC
sard FPR
bosch 044 intank
apexi power fc
q45 AFM
custom 4 inch intake
nismo 550cc injectors
current power is 317kws
with ignition advance average around 18 - 19 degrees
i have been advised that if i drop the boost to say 20 - 22 psi and increase the ignition advance to 21-22 degrees the power should head up towards 330 - 340, without to much pinging.
but thats yet to be proven on my set up.
standard trans
mv stage 2 shift kit
large trans cooler.
Very nice mate ! Are you ever going to have a play with it on the strip ? Would be cool to see what mph it pulls !
What afr's it running top end ?
its near level on 12 afr once on boost.
im planning on dropping that down to about 11.5 afr then pumping some more ignition advance into her.
Hey i would love to stretch her legs down the strip but we dont have one.
bloody government over here are slack, and private enterprise is even worse.
Glad I found this thread... I will add my Datsun 120Y that has a RB20DET auto
Engine has
20thou forgies
Walbro + Bosch 044 & surge tank
GTR ingectors
Stock AFM just before the throttle body
3" exhaust
Garrett GT35R 0.63 exhaust
38mm Turbonetics external gate
Auto has
MV shift kit
MV manual shift controller
B&M pro ratchet shifter
4200 stall converter
trans cooler
185 kw
I could only find my 13.1 @ 113 timeslip from yesterday but it has done a 12.9 @ 113.
Best 60 foot is a 2.25
I use 205x50x16 Toyo R1-R and a 3.7 lsd diff.
I have been told I have the incorrect type of muffler fitted and i need a straight through design.... Damn restrictive V8 muffs.
post-24062-1162824263.jpg post-24062-1162824293.jpg post-24062-1162824441.jpg
Edited by RB120WHY
    • Inspiration: https://www.nissan-global.com/EN/HERITAGE_COLLECTION/Primera_GT.html
    • Yeah, hard to find and a pain in the ass to change with the transverse engine. I’ve worked on a GTiR before and it’s not a job I’d ever want to do again. theres a company in South Africa that makes RS3 gearbox adaptors for the AWD SR20 including gearbox mounts, so I could modernise it and go a dual clutch with paddles. For now tho, it ticks all the boxes. Super cheap, can throw the kids and their junk in the back, and SR20 that I can turbo cheaply, a CVT that’s not a dog’s breakfast like the V35, and has 80% interchangeable parts with stuff I can source from the wreckers cheaply…. But it’s still unique. I love the wagon back of the Autech version. It’s cheap enough that I can buy another stock manual FWD Primera with SR20VE, swap the gearbox to the N15 pulsar short gear ratio box, swap out the brakes to the R32 ones I pulled off my 32, register it on club plates and take it racing. $1300 shipping from NZ. Heaps of parts and aftermarket builders for transverse SR20’s in NZ.
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
