Just giving a shout out to Gavin from xtremeline who detailed my car today.
Seeing as he was one of the SAU-VIC sponsors i decided to book a full detail inspection. Including engine bay, interior and exterior. Also explained all the steps on maintaining and how to take care of it after he has detailed it. Gavin has been detailing for over 3years and is a friendly guy to talk to.
His details can be found in the sau-vic members area or you can contact him via 0407 559 770
Now for some pics!
(About to purchase a stock wing for the car, so the cwest gtwing coming off :rolleyes:)
dscn2645largeec8.th.jpg dscn2650largegn9.th.jpg dscn2651largelt2.th.jpg dscn2674largevq0.th.jpg dscn2665largean7.th.jpg
https://www.sau.com.au/forums/topic/131820-xtremeline-detail-pics-inside/
  • Replies 41
how much of a discount did this Gaven dude give ya for adverting his work? :rolleyes:
Im only recomending him due to his quality of work. He is already a sponsor of sau, and has plenty of sau-vic customers. I am only providing proof of work so others do not need to take a risk.
looks good man - one of hte nicer r32s i have seen
Its a good idea also to give credit - whether or not the person/place is a sponser of SAU. If they do good work, then chances are other sau paying and non paying members will also wanna take it to that person/place :rolleyes:
Cost me $150 for interior, engine bay and exterior. Took about 3 hours to do and comes to your place.
Was just about to buy a stock spoiler from a member but he was at deca for the week, but if a bigger spoiler pops up onto the market ill be sure to buy it :laugh:
Products he used were meguiar's cut/polish, wax and techwax from memory.
The interior and engine bay wasnt anything special. A couple of squirts of some liquid? (could have been a special interior cleaning product or regular soap), a wipe down and vacuuming of the car. Probably if you asked for a closer clean of interior and engine bay it would obviously take longer and probably cost more. His priority in my case was the exterior look of the car and thats what ate up the 2.5hrs of the 3hrs it took.
Looking right now at the water jets, there seems to be a small white ring around them which ill probably remove tomorrow.
Car looks tops but i have to agree get a bigger wing...
Dezz can u ever post without having something incriminate to say???
Patrick if you get a fine needle and run it around the washer you will get the stuff off no worries.. You'll find it's almost impossible to remove from a spot like that when the wax is wet...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
