Hey guys just got some new turbos fitted to my car and i thought id post the dyno graph up to see what u guys think. Running sort of a light tune to keep my engine alive during track days until i can afford to get a rebuild done :P . Its using a djetro pfc and still on a cat back. Plan to get a turbo back soon to try and get it to be more responsive. Any comments welcome. Cheers :D
Edited by Yawn
what injectors you running?
Im running nismo 600cc ones.
3lit3 32, from what i know i should be able to easily get 500+ hp atw but i dunno about 700 heh. Yea I know im not even close to pushing the turbos but as i said, im trying to take it on the safe side for now as i do some track work. Once i get a full engine rebuild ill go all out >_< . The dyno run was on 2 wheels.
Cheers
Hey guys just got some new turbos fitted to my car and i thought id post the dyno graph up to see what u guys think. Running sort of a light tune to keep my engine alive during track days until i can afford to get a rebuild done :D . Its using a djetro pfc and still on a cat back. Plan to get a turbo back soon to try and get it to be more responsive. Any comments welcome. Cheers >_<
Nice, what boost are you running? Looks around 20psi?
seems quite laggy to me. 1 bar at around 4500rpm. nice power though, but they must be fairly large low mouts as the resposnse does not look that great.
yeahh from what i know, the -5 model is slightly bigger than the -7 model, which (i think) is comparable to hks 2530s. Yeah it is rather laggy but im still running a catback so im hoping the graph shifts to the left a bit once ive got front pipes/dump pipes in.
yeah West im running slightly under 20 psi. Btw how do you know its in 5th gear? :P They are bigger than both the gt-ss and the N1s
Cheers
Edited by Yawn
yeah West im running slightly under 20 psi. Btw how do you know its in 5th gear? :( They are bigger than both the gt-ss and the N1s
Cheers
I was only guessing :bunny: mate.
Damn, those things are bigger than Gt-ss, mad fun their. May i ask what condition is your engine in? Did you do a low boost run? Say around 14psi?
west mate, it would not be in 5th gear. most DD dynos are rated to 200km/h only. It would be either 3rd or most likely 4th gear. Even if it was in 5th (which i can promise it wasn't) it shouldn't make much difference at all. if anything it may build a little earlier as the engine is under more load.
Thank you very much, i dont know much about Dyno thing.
Hey guys just got some new turbos fitted to my car and i thought id post the dyno graph up to see what u guys think. Running sort of a light tune to keep my engine alive during track days until i can afford to get a rebuild done ;) . Its using a djetro pfc and still on a cat back. Plan to get a turbo back soon to try and get it to be more responsive. Any comments welcome. Cheers :P
Mind if i ask who or which work shop that did the tune?
Are you still running standard injectors? If so whats the percentage shown at 300kw?
D-Jetro is still very new to VIC tuning scene i think though i'd love to have it, just to get rid of the air flow meters.
Airlfow meters is what makes the PFC so powerful. D-Jetro I assume was made for the american market as they had no idea how to tune a MAF based system. If you want to go MAFLESS get an Autronic because the time/cost taken to wiring in and tune will probably about the same to plugin and tune a D-jetro and at the end of the day the autronic is better.
On a more advanced engine e.g Fully rebuilt , cams/head work and tune the lagg can be taken care of through playing with cam timing , while still not loosing any of the mid range top end punch these puppies deliver.Just take it to a tuner who knows the fine tuning insides and outs of the RB26 and you will be very rewarded.Should be able to see full boost 22 -24 psi at 4500 rpm or just under but they will start pulling hard much lower than this so are still a very streetable turbo set up.
Alot of the gtr forums I visit from around the world rate these huffers above 2530s for there response and big delivery of power in the top end.
On a fairly stock engine Id put a gtss or the 2860R -7 turbo upgrade ahead of these unless of course you are taking it further down the track,these are purfect for a hard tuned street machine.
On a fully worked engine these turbs are good for 380 - 410 awkws
Just my opinion though. :)
Edited by DVSGOD
one questions I have always wondered is assimung ur've upgraded your turbo, AFM, injectors, fuel pump PFC blah blah and your making a good 300+rwkw...at what point do u need to consider internal upgrades or is this dependant on how hard you drive it? In a street app where you may only trash it occasionally...I'm wondering how the internals hold up over a 1-2 year peroid..on say 1bar or just a little over.
Just intrested as I have a RB25 with the same mods and similar output as this dyno i.e. about 300rwk on 1bar and all the goodies...now I'm wondering how long the engine will last hehe.
Hey guys just got some new turbos fitted to my car and i thought id post the dyno graph up to see what u guys think. Running sort of a light tune to keep my engine alive during track days until i can afford to get a rebuild done :( . Its using a djetro pfc and still on a cat back. Plan to get a turbo back soon to try and get it to be more responsive. Any comments welcome. Cheers :P
I got an r 33 GTR with a built motor and same turbos and im pushing 366 kw at all fours on 22 psi and pump fuel. My car makes 308 kw at 5600 rpm id post the dyno sheet but dont know how
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
