Booked in my r32 gtst for a $14 pedders suspension check, seeing as I've only had the car for a week would like to know if there are any problems to be fixed.
Results were:
Shock absorbers:
Left front: 27
Right front: 27
Left rear: 22
Right rear: 24
Pedders stated new shocks are rated 22, so nothing needs to be fixed there.
Only problem were:
Upper inner bushers worn $137
Slight play lhs mounts moving
LAB $132
Wheel align $55
Total ~ $324
Should I go ahead and book the service with pedders?
Also spoke to the person about pedders extreme suspension vs japanese made, he says pedders australian built and made for aus conditions plus not as stiff as imported :(
Thanks
- Patrick
https://www.sau.com.au/forums/topic/132237-pedders-suspension-check/
what is a LAB?
For inner arm bushes you should check out whiteline or notlec adjustable camber bushes.
Alignment price is good for a 4 wheel alignment but make sure you get the other work done first
Pedders charge $110 for a 4 wheel alignment.
The above quote is just the front wheel alignment
For bushes & your suspension needs its hard to go pass Whiteline items. Also, if Pedders had some idea about the Skyline they would of advised you to have a 4 wheel alignment done. SydneyKid has listed - Centeline Thomastown; & Traction Tyre & Suspension Rowville, as reputable suspension places in VIC.
I took my GTR into Pedders up here for the $14 check & dropped a few comments as hooks-in-the-water to see if they'd bite & yep, they sure did!!
Firstly they wouldn't let me in the workshop to SHOW me what needed to be replaced, which to be fair is the letter of the law BUT then they came back with a list of needing to completly dis-assemble the rear-cradle & replace all the bushes along with the front steering-rack being shot & needing to be re-built or replaced. Stupid $$$ & 2wks later I could have my car back.....
I then took it to a mates workshop & put it on the hoist. The car needs a RH front tie-rod end, a front CV-boot & not a lot else. Whilst the rest isn't brand-new, it doesn't need replacing right now either.
Anyway that's my experience, make of it what you will
that's pretty cheap. most good place i know charge between 100 and 150 if we are talking:
adjust front toe
adjust rear toe
adjust front castor
adjust front camber
adjust rear camber
that's a fair bit of stuff to do, and after doing camber things must be checked again as it can affect castor. and after doing castor another check is required. so it takes time.
Mate you could take a new car their and they would say it would need changing. :P
When the inspection was finished, they left my car on the hoist and asked me to follow him into the workshop. He then showed me what was wrong and what needed to be fixed, then lowered the car and printed out the invoice etc.
Havent done anything yet, looking around at other options.
Pedders and my local import speciallist gave me an identical list of suspension issues, so I figured that what they were telling me was reasonable. Always get a second opinion if you think you're getting taken for a ride!
Or could it be that Pedders and my mechanic are conspiring against me?!?!?!
Mate you never know.
These pedders outlets are franchises and i spose its the luck of the draw of which one you take it too.
They probly get a 6 week training course of how too rob people legally and get thrown into the business without a clue. Some pedders may be good depends on the owners. All they want is profit which im sure everyone wants, but not robbing people they way they do it.
My experience never go back.
Edited by subzeroR33
But wouldnt Joe Blow who "specialises" in Skylines and other imports would wonna rip you just as much as Pedders in this case? At the end of the day, everyone wants to make money. If you really want to save a buck, become friends with a mechanic and get him to check your car over, this is the only way.
My family friend mechanic told me today that you dont need to machine all disk rotors when changing brake pads... often its not needed at all but 9/10 places will tell you to do it, why? more money for them.
I cant imagine how much chicks get ripped everytime they service their cars...
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
