  • Replies 152
Posted Images
I dont know maybe I should leave this power plant in call it cute power though I could never shut the bonnet on her my beautiful grandaughter
she likes to help popa only trouble she likes to help with a hammer arrrr noooooo :(
awwww!!! That's adorable!!!
https://www.sau.com.au/forums/topic/132547-again/page/5/#findComment-2953334
  • 4 weeks later...
Hi guy's and gals
Haven't posted for a while been busy at work ,6 days a week suck,just thought i'd post up some picks of where its at now .
Going on holidays at the end of the week so hopefully will get it finished then
https://www.sau.com.au/forums/topic/132547-again/page/5/#findComment-3013397
Peter
I have read and studied this topic in detail and I am totally impressed by your attention to detail in your rebuild.
At a technical level there are a number of things that you read about that everyone talks about but in practice no one does (eg oil return line from back of head into the sump). Your attention to detail in this area is better than anyone else that I have seen.
You are to be commended on your rebuild and I would like to see the car in the flesh at a SAU function to further admire your work.
https://www.sau.com.au/forums/topic/132547-again/page/5/#findComment-3015254
Hi All
getting closer just thought id post some picks of some intresting info i came across with the nismo fuel pump and the gtr fuel pump seems there the same numbers on them tried to take a pic but don't think they turned out to well, bought from nengun and same part numbers for rb20 and sr20det the nismo one has a band around the top.And a bit of a pictoral on removing the hicas and plumbing and what I did the reroute the p/s fluid and fitting hicas lock bar as well as fitting pineapples for traction
post-7066-1175677068.jpgpost-7066-1175676884.jpgpost-7066-1175676792.jpgpost-7066-1175676689.jpg
https://www.sau.com.au/forums/topic/132547-again/page/5/#findComment-3029528
Ok guys and gals
Car is 95% complete and running took it for its first run on saturday night felt good to drive it again had to make it short though cause the oil cooler has a slight leak that has to be fixed latest engine bay pick's up for you with some old pic's of what it used to look like
Cheers Peter
https://www.sau.com.au/forums/topic/132547-again/page/5/#findComment-3052670
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
