  • Replies 42
Posted Images
Dunno why you'd use something like the prehistoric castiron VH block when you can use a lighter all-alloy VK56DE
the titan engine with a nismo supercharger would be the way to go if you wanted to keep it in the family... expensive compared to an LS1, but definitely sweet.
god I want one to jam into a Nissan Gloria or some sweet little sedan/cruiser.
The VH engine is also all alloy... the VK56 lost VCT got lower compression and a longer stroke... not good if ur after a high revving sports car type oriented engine... if u were after something for a burnout car then perhaps it would be a goer..
The biggest thing is cost and availability...
Very doable - all the examples of where it has been 'done', however, and all RWD vehicles. The topic is specifically about a gts4.
What with all that 4wd gear, and a different bell housing (is my terminology correct?), its more than a little different.
Cant you get the VH41DE in a 4wd version ie it must have the correct sump etc a 4wd application?
It might be the way to go if you want 4wd V8 instead of this idea over head valve (push rods) 2 valves per cylinder is performance.
OHV 2 Valves per cylinder should have died many years ago but GMH are a bit dim.
I n asnwer to your question with someone that would be willing to fabricate the parts needed yes you could do it, finding that person that will do it for a reasonable price would be near on impossible.. i have the gear to do but do not have the time nor the money..
If I was going to do something like this, how about a Toyota 1GZ-FE ?
V12, 5.0 litres, quad cams, all alloy. It would be like having two RB25DE engines side by side. The engine length would be very similar, so the 4WD sump might come pretty close to fitting with just an adaptor plate.
The Toyota V12 is very similar in design and construction to the well known Toyota alloy V8, but with four extra cylinders. It is supposed be a very well built engine, ideal for high Rpm. With a few modifications it would howl like a Ferrari, and make a pretty unique car.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
