Thanks Fonkeymonkey for confirming the 4/95 build date.
I purchased my baby from Unique Auto Sports as a 1995 V Spec. It has the V Spec badge on the bootlit and the usual V Spec components like the the fins on the rear diff housing.
What is the difference between a V Spec and a V Spec N1?
Thanks
  • 1 month later...
Can you please check this one for me:
ECR33-106340
The model code is GGKBRTFR33VZAAALCA
I do not know what the last letters stand for AALCA - can anyone shed some light on this?
Edited by Victory
  • 4 weeks later...
FB13-577940
hb14001299
Neither of these VIN's are recognised by my version of FAST, but if you type in 'B13' or 'B14' into the 'Model Series' area (and hit return), you'll see various drop down menu's appear from which you can select engine type, body type and a number of other options. That might narrow it down for you to something close to the cars in question.
It seems that cars manufactured outside of Japan are not covered by some versions of FAST. Mine does not cover Nissan models built in Australia, for example. If yours were built locally or outside of Japan that probably explains what's happening.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
