Merry Christmas "J" and others who have served this thread so well for so long!
If you said that you've worn down the finger prints off your fingers I'd be inclined to believe you!
Thanks "T" :D
  • 3 weeks later...
Can anyone tell me if my gtr le mans is in fact a genuine le mans? All numbers match, but doesnt have dual airbags? Vin plate details:
E-BCNR33
Chassis number: BCNR33-023007
Model: GGJPRQFR33ZDA-ARAA
BT2 K
RB26DETT 2568 CC
FS5R30A RC41
5
Help would be greatly appreciated :) only bought 3 weeks ago but after researching more and more finding out i may have bought a non gen le mans. Still a gtr so is still a nice car but still, wanna know what i have. Thanks.
E-BCNR33
BT2 K
RB26DETT 2568 CC
FS5R30A RC41
5
I'd say so.
BT2 = Champion Blue from factory were only allocated to the Le Mans Editions.
Thanks mate :) just now need to know why mine has a series 1 dash :/ lol
I'd say because your R33 GTR was built in June '96.
From memory:
Series 1 = 1995 - 1996 - No passenger air bag, only air bag on steering wheel.
Series 2 = 1996 (Late) - 1998 - Has Passenger Air Bag and updated steering wheel (I think?)
Series 3 = 1997 - 1998 - Has what the Series 2 got + Xenon Head Lights, red stitching on seats, lower front lip and twin air vents on the front bar to vent more air to the intercooler.
  • 2 months later...
Guys, I am having trouble with the 64-bit version of the Nissan FAST software. I have input the VIN, the model number comes up and I can search, but I only get the "Part Code" and not the "Part Number". Can someone explain how to get the part numbers to display?
You have to press 'part no. search' up the top (looks like an open book) and it will output the part number and bring up a prompt if there is more than one part for that part code
  • Like 1
Hi Guys
Can someone look this one up for me?
BCNR33-007638
GGJPRWFR33ZDA-J---
Thanks
BCNR33-007638
GGJPRWFR33ZDA-J---
V-Spec (Series 1)
1995-06
KL0 Spark Silver Metallic
V-Spec (Series 1) With A Rear Wiper
GTR-Registry.com has more info.
  • 3 months later...
  • 11 months later...
I've posted this in the other "Downloading FAST" thread as well, but no answer yet. Can anyone else with FAST tell me what your program and CD dates are (> Help / Version Info) ?  I have recently acquired a 2004 model car but my CD's only go up to 2001/10.  I spent two hours downloading what was labelled as "FAST2010", but I think they typo'ed the name because it was same as what I already had, 2001, not '2010'.  Does anyone have FAST with CD's later than 2001/10?
  • 2 months later...
Hi Strutto ...
I have a question, maybe you can help me out here... ?
I used to be A authorised Nissan workshop and had Fast at the time, but I cant seem to get fast working with Win. 10. Also we are located in Denmark so we have the european disc for Fast. Anyway...
I have this R32 / chassis nr: BNR32-013497 from 12/1990 , an "early" model.
It is imported from Malaysia, and came with a nissan GTR steering wheel - I noticed when driving for some time 20 minutes or so, that the steering jumped - no Hicas light came on - but the rear wheel turned slightly when it was supposed to be straight.
checked the Hicas with a Nissan Consult II tester - No faults but read 153 degres to the left on steering angel sensor when the steering wheel was straight,
I took the steering wheel off, and yes it was the new type with the holes at 12 & 6.
when I lign the steering angel sensor up with the middle point of the neutral signal it of course lines up at 1 & 6 o'clock.
So I have the "early" type of steering angel sensor and the new type steering wheel...
I have looked at some parts catalog pages, and seemed to have found that the early steering angel sensor should
be part number: 28475-01U00 or alternative number: B8475-01U00. (there are no number readable on the sensor equipped)
The Question is I think I have found the later version of steering angel sensor equipped from 09/1991 -  models
wich should have the number 28475-01U11 or alternative number:  B8475-01U11.
Do you know if this number are for an sensor with alignment 12/6 o'clock and does it fit on the car with the early version´s ?
Cause Nissan europe cant confirm this for me.
If I could buy the new type sensor that fits the steering wheel, then I can get the Hicas working with the steering wheel at the right position, right now I drive around with the steering wheel turned 153 degrees and the Hicas works superb.
Hope you have the answer for this - best regards Lars.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
