Could you guys get a table going for the some of our cars?
btw. mine is done thru Advanced Autos as well - they sound like they're hiding something ie. non V-Spec badged as V-Spec.
Here's mine:
ECR33-058499
T.
Model: GGKBRTFR33VDA--JD-
Year 06/1995
Colour: KL0
Int colour: K
Manual RB25DET with HICAS
2WD
*** PARTS LIST DISPLAY ***
VIN-Code : ECR33 -058499 Model : GGKBRTFR33VD
Model Series : R33 Prod.M/Y : 9506 Color :# KL0
ÎÞÃÞ¨ : 2K ´Ý¼ÞÝ : RB25DET »½Íßݼ®Ý : HICAS ¸ÄÞ³
¸ÞÚ-ÄÞ : GTS25T/M Я¼®Ý : MT.F5
Part Ord Part No I/C Per Sal
No Code Qty ALTERNATE PART NO CD DESCRIPTION Veh Cod
*** THANK YOU FOR MAKING IT USE A DAILY OUTPUT PURE PROPER PART REALLY. ***
jtil, if your car was made before 2001 (date of the DB that everyone's downloading) then it will show up. I've ordered the April 2004 Jap FAST on dvd from japan, we'll see how that goes when it gets here.
And mindflux the au db has the 100 R32 GTR's that were released in AU and all the R31 Silhouettes i'd assume. But I can't share it as that was part of the deal, sorry guys. I'm more than happy to run the VIN's thru it tho.
Hey guys could someone please check a vin for me and post the results. Got my correct vin number this time, was a bit of confusion with it.
HCR32-001702
Thanks in advance
VIN-Code : HCR32 -001702 Model : KRCR32RGFSME
Model Series : R32 Prod.M/Y : 8905 Color :# AH3
ÎÞÃÞ¨ : 2K ´Ý¼ÞÝ : RB20DT ¸ÄÞ³ : HI.2WD ¸ÞÚ-ÄÞ
Я¼®Ý : MT
strutto looking at the part numbers on some parts i allready have it does not show full parts listing IE
rb20det
say a timing belt on fast is is listed as 13028
but the full part # is 1302820p25
does anybody know how or where the full parts listing is for each part ?
funkey monkey.. I have the 09.2003 dvd. I did upload it a while back but not sure what happened to it now.
My one seems to be missing a few cars... ie, mine and a few i checked in this thread. Would also like to know how to get it out in Jap font so i can run through a translator.
dave.
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
