Anybody know the best jack points for a trolley jack on an R33 both front and rear?
I think I remember people going "um and er" and "don't do it there" in answer to a previous thread but no firm answer as to where the best place to do it is!
So far i've used both just behind the wheel on the body (which is the usual jack point for a normal jack).. worked but bendy the metal ridge a bit (yeah, yeah,...whatever but i needed to do it).
Another time tried slightly further in which i thought was the chassis rail.. this rail that comes down slightly near the gearbox. Again, bent that a bit but i got it up to do what i needed to do then. But i don't want to use that point for the same reason as above.
I know i can't using these points as eventually they'll cause long term damage to the undercarriage.. so i need to know the correct ones people use. Failing that i'm just wedging a wide board under there to distribute the weight and doing it that way.
Thanks muchly..
https://www.sau.com.au/forums/topic/13382-jacking-an-r33/
  • Replies 75
Posted Images
Does anyone have pictures of the particular parts they are talking about ??? It would make it alot easier to describe the places with pictures people can relate to.
I mean the diff is a no brainer, it's like the jack was made for it, but up the front of the car it's a little trickier ...
https://www.sau.com.au/forums/topic/13382-jacking-an-r33/#findComment-261401
I use the front crossmember on every car I've ever owned, and the Skyline is no exception. (it's the bit that your front suspension arms attach to, under the engine)
The problem after lowering it is that the jack is too tall to go under the front bar! So I have to jack up the side a bit using my tyre jack, then use the trolley jack to jack it up the rest of the way, and leave the tyre jack there so I can lower it back down onto it before taking the trolley jack out.
https://www.sau.com.au/forums/topic/13382-jacking-an-r33/#findComment-263798
That's a bit of lateral thinking there Jay! More reliable and easier than the tyre jack that's for sure. I never thought of that. Probably because I don't really have anything like that in my garage that caught my eye to give me the idea at the time :) I'm gonna go visit my dad and see if he's got any bits of wood he don't want anymore.
https://www.sau.com.au/forums/topic/13382-jacking-an-r33/#findComment-263859
lol, i saw some guys testing a v8brute do exactly that...park on the plank of wood. Except I had to ask what the hell it was about.
JimX, do you have a pic of the crossmember? Do you raise one side at a time, or both from the middle?
https://www.sau.com.au/forums/topic/13382-jacking-an-r33/#findComment-263987
I don't have any pics of the crossmember, but if you just follow the suspension arms to a pivot, you'll see a big metal beam that goes under the engine behind the sump. It's basically the front support for the whole front of your car. The trolley jack goes in the middle and you raise both front wheels at the same time in this manner.
https://www.sau.com.au/forums/topic/13382-jacking-an-r33/#findComment-264072
  • 8 months later...
I need to jack the rear up, where exactly is the rear diff? I see a circular metal piece after the rear jacking point. is that where it is? I need to take the wheel off for some chrome cleaning. And I already purchased some CAR STANDS that can hold it for long period of time. The problem now is, once I jack up the car at the jacking point, where do i put the stands?
I was think jacking up the car at the diff as you guys said, then leave a stand on the jacking point. lower the jack and wala, the line is STANDING ON A STAND. help me out please. is this right?
https://www.sau.com.au/forums/topic/13382-jacking-an-r33/#findComment-606069
Yeah JimX is right. If you've ever pulled the front end of a Skyline apart you will know that this part of the car is extremely strong. (Crossmember)
Just watch that you dont do anything silly like put the jack under the sway bar.
Alternatively you can use the standard jack locations as indicated by the diagram in the user manual. If your trolley jack does not have a notch cut to go over the metal bit then just get a block of wood with a notch in it to put on top of the jack.
If you dont have a user manual then the jack locations are also noted by a sticker on the standard wind up jack.
https://www.sau.com.au/forums/topic/13382-jacking-an-r33/#findComment-606168
The jacking points at the front and rear of the sills can be seen if you look underneith
...a small rectangulat plate just inboard of the lip has a 8mm hole in it's centre.
trolley jack under the diff for rear or crossmember for front and stands under the sill jack points
to raise just one side of the car a length of 2x4 timber along the sill between the jack points but leaving enough room to place the stands when its up trolley jack under the timber at the balance point where the whole side of the car goes up evenly. Usually a few inches forward of the rear of the door....trial and error!!
If you havn't got trolley jack and at least 2 stands......you shouldn't be doing it.
https://www.sau.com.au/forums/topic/13382-jacking-an-r33/#findComment-606275
Hey predator & all
I don't know a great deal about "jacking the line" but I do change the oil every 5,000k.
A hint for those with car ramps that don't fit under the front bar is....... to turn your wheels fully in one direction, place a ramp under the wheel that is pointing out (eg left wheel if steering left) and drive up onto this ramp.
You now have enough room to do your oil change. Simple but effective.
Enjoy
El Bee
https://www.sau.com.au/forums/topic/13382-jacking-an-r33/#findComment-606455
No one's had any trouble catching the steering rack whilst using the crossmember at the front?? I was gonna use the crossmember like I usually do, but it looked like some pressure was going to be put on the rack so I got turned off using it...
https://www.sau.com.au/forums/topic/13382-jacking-an-r33/#findComment-607534
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
