Hey all,
I took my car down to RE Customs today. Spoke to Ray who was cool and friendly about my results. Basically i got the stock boost level raised to 10 psi. I was told that the engine was knocking. Would knocking occur if the spark plugs weren't regapped? Also when i fully open the throttle the engine seems to splutter (mainly around 5000rpms) before revving clean to redline. Would this be caused by the plugs aswell?
My car is an auto 95 33 gtst. Mods are 3.5 inch cat back and POD. Boost was raised with a bleed valve.
Also what are your opinions on the dyno read out.
Thank you to all that reply.
https://www.sau.com.au/forums/topic/134479-got-my-car-dynoed-today/
shouldnt be knocking with those mods... as mentioned fuel pump would be the only reason as it should be rich as upping the boost
Also maybe look at getting a better bleed valve/boost controller looks like by the time you are making max power it has dropped back to 8.5psi
cant say for sure without seeing your afr but generally with those mods you would see you car richen up a fair bit eg maybe a 11:1 or 11.5:1 if you get the afr and it's above 13:1 i would get it checked out although any good dyno operator should have said something and stopped the dyno session.
But it's an easy task and worth checking anyways pull out your plugs check the gapping and check your coils are in good nick.
if its coffing and farting round 5000 u should gap ur plugs down mine r at .7 sum ppl say its to low but when i had same mods my car was doing this and that gap fixd it 100%
also if in doubt about the fuel pump put a fuel presure reg on it and up the presure to say 45 50 and see if that helps with the pinging if not could be shitty fuel mine knocks (pings) if i run optimax but 98bp ultamate it dosent
I'd think about closing the plug gap to 0.7 or 0.8, but at only 10psi I can't see this being your problem. If your getting a stutter at 5000 I'd be checking plugs, coils, fuel pump and injectors, make sure they are all working OK. I'd also be checking the simple things, air filter, fuel filter etc.
you are definetly hitting rich and retard
dont bother changing plugs or anything else
turn the boost down see if the problem goes away
if so, which im pretty sure it will, time for a piggyback, remap or stand alone ecu
Sorry for the late reply. I run my car on Bp ultimate. Seems to run better than any other fuel. So getting an SAFC should rectify this problem?
Thanks
Well yes but it still seems really low for 10 Psi. I hit 175 with standard boost, std cooler, pod and cat back. I wouldn't up the boost till you at least get a Hi-flow cat and perhaps a dump or split dump pipe. Seal up your plugs to be sure and you should be able to get close to 9Psi without even touching the boost controller.
Your plugs at 0.8 should be fine. Whilst .7 or .6 may seem to fix a problem, it usually only "covers it up". Find the cause of the issues rather than trying to cover them up methinks.
Checked my coilpacks and they seem to be fine, no cracks etc. My plugs are NGK iridiums which are only about 6000kms old. The air filters seems to be fine, its basically new, don't know about the fuel filter though. I haven't changed it since i bought the car 20,000kms ago but it was apparently changed before i purchased it. Gonna look at A/F ratio on monday. Could driving my car around temporary in this state potentially harm my engine? Also can ignition timing be cause of this problem? Does it have to be retarded or advanced when running more boost?
Thanks all
Unfortunately there isn't much you can do to fix the tune of your car without getting a power-fc or some other computer, the computer retards the timing and richens the mixture when it detects the car is running outside the factory specs(more boost).Cars with a catback exhaust can hit rick and retard on a cold night.
Getting A/F ratio chart on monday. Will post up when i have it. Can't afford a power FC at the moment. I'm not looking at going over 190rwkws with the basic mods (turbo back, cat, Intercooler) Just want good street power.
pretty much no-one has paid attention to what he has said. the car is knocking, that is causeing the power dip. not r&r. there is very little chance of the car hitting r&r at 10psi with stock dump/front and cat. it wouldn't flow enough air. if he did, then when he did put a new dump-cat section on it would make it hit at about 9psi. i'd be getting the fuel pressure and timing checked.
i would also be looking at a new controller, as has been said. it shouldn't bleed off that much boost at 10psi.
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
    • Oh and some up-and-comings; New rear drivers wheel bearing. I'll do that this weekend while the diff is out. The car is already up and the d/c axles and missing exhaust will help with space. This is the last bearing for me to do and I've been dragging my feet on it. I also have some new EBC blue stuff pads for the car and some new brake fluid. I haven't ever flushed the fluid in this car and looking forward to it. I have 600 degree fluid to put in. Not exactly "race fluid" but better than the typical stuff I have been using.
    • A proper clutch/plate type mechanical diff with quite a lot of pre-load and high locking % is better for drifting. Much more consistent in its behaviour. A helical can be annoyingly vague and inconsistent in how it responds under the sorts of abuse found in drifting.
    • Some updates here. I pulled the entire interior out, minus some trim to respray the seats with Colourlock dye. It turned out really nice though I accidentally let the dog in the car after and she scratched up the front seat.  This is what it looked like before, the colour was just washing out everywhere but thankfully the leather was in good nic. Then after the respray   And after the bloody dog jumped in The headliner is out waiting to be retrimmed, but it will stay out now until Nov - see why below. I replaced the stereo/headunit with a period-styled Android headunit. I have no after pics, but I'll get some. This is because of the missing pixels. I tried to fix this twice with replacement ribbon cables but couldn't. Also the bluetooth interface I'd bought for this was crap. Then there's the rusty roof. Pics and info in this other thread. I have decided to get this repaired professionally, but I'll update that thread. This is why the headliner will stay out for now. I'll be getting the roof and bonnet resprayed at the same time the rust is fixed. I also had an interesting issue with my drivers door lock.  For a small period I was having issues getting any 12v power to the car - I mean *any*. It would have no dash lights, nothing. It happened while I was at the shops and I couldn't get in the car. So, we had 2 problems. The most pressing here is that I was locked out. I have only a single physical key hole on the car, the drivers door and no amount of turning would unlock the car. Surely it doesn't need power for this? The second issue is why am I losing all power periodically, The battery isn't dead, its almost like the battery isn't even there. Two issues that were surprisingly easy to fix. You fellow BMW over-engineering lovers will appreciate this. The lock in the door has 5 states; mechanical lock, electric lock, neutral, electric unlock, mechanical unlock achieved at -90 degrees, -45 degrees, 0 degrees, 45 degrees and 90 degrees. Although, the unlock is towards the front of the car, so opposite for LHD countries. Sticking the key in and turning 45 left or right is what is used 99% of the time. It activates the central locking etc. 90 degrees is for dead battery access and, obvs, only un/locks the one door. But because the mechanical lock is never used and is 27 years old, it seizes up. I was totally unable to turn the key far enough to get to the mechanical unlock (At the time of locking myself out, I didn't even know this was a thing). I eventually did it with some vicegrips and teflon spray.  I made a quick vid for other E39 peeps.   The battery issue is totally new to me also - It wasn't making sufficient contact between the post and the terminal. The terminal was bolted on tight, but the car wouldn't have power. After checking the battery with my multimeter I accidentally contacted the terminal and the battery post and the car got power. The battery was only a few years old and in good condition. I cleaned the post and the terminal with a wire brush, bolted it back on tight and never had the issue again. I'm still surprised that despite having solid contact it didn't work. Also, the car was getting Warragamba sized pools of water in the back when it rained. My initial concern was another rust problem. But when I went out on Weds while it was raining and while I had no headliner in I could see a steady stream of water coming through the roof mounted aerial. As this aerial is for the (now removed) car phone I pulled it out and whacked a blanking grommet in the hole. It seems fine now. I'm thinking I might get the hole permanently filled when the rust is fixed. Moving forward and things in progress; The tailgate needs some attention. I have taken all the trim off to clean it all and address some small rust spots. I have partially done all of this but I'll finish it up hopefully this weekend. As all the trim are now entirely devoid of trim clips I have bought a heap of strong velcro and I'm hoping it does a good enough job as any of this trim in good condition is super expensive and usually in Europe as we dont have many of the wagons here. Suspension and brakes!!! This is exciting. In the front; New control arms New sway bar links New lower Eibach springs (the only modification I'm planning on this car) M Sport shocks (these came with the car and will replace the longer shocks in the car) New top mounts Used 540i calipers (stock brakes suck!) New 540i disks and pads (22x296 mm for 528 and 30x334 mm for 540i) New front wheel bearings (thank all that is holy for bolt on bearings!) Annnnd in the back; New control arms New sway bar links Adjustable air suspension arms (fool the car into what the current height is so the self levelling suspension can match the new front ride height) New ball joints I'll also be doing a brake fluid flush while I'm in there. I'm planning on switching the car over to the 16's that came with it so I can clean up and respray the M Sport 17's. They've lost a lot of colour over the years and have some gutter rash. None of this will start until the E90 is back.
    • You mean you will regret it for drifting duties? I don't quite follow.
