i got this little sticker on the motor cover that says something about 100,000km, im guessing its something about the timing belt which needs to be done at 100,000km right?
anyway i got a pic here so if anyone can tell me what its trying to tell me, i'd be happy and that :rofl:
https://www.sau.com.au/forums/topic/135423-timing-belt-a-sticker/
Correct... you may want to consider changing the belt around 90,000 KM mark and definately NOT over 100,000 KM mark, reason being, Jap cars have most of their speedos wound back. And the LAST thing you want snapping is your timin belt, if it does, your engine is "capoot."
Hmm Sir-D thats a wee bit suss. I use to own a 1989 nissan pulsar sss before owning my skyline and one day while driving from the gold coast to brisbane my timing belt snapped on the pulsar, the cars power died immediately and i had to pull over and call racq. The next day they replaced the timing belt and all was fine. Apparently the nissan pulsar had some sort of safety mechanism on it so if the timing belt did snap the valves or pistons (im not a mechanic) etc would retract and no damage would be done to the motor. My question is wouldnt skylines have the same safety technology?
By the way my skyline has traveled according to the clock 107,000K's and still im yet to have it serviced. My funds are low and i have been quoted between $800 to $1000 for the magor 100,000K service. :(
Edited by LoNg_ShaNks
i dont think rb's have that safety mechanism but i could be wrong. i know for a fact that in celica's and camry's - same motor, a snapped timing belt doesnt cause any damage to the engine. jut replace and away you go.
I dont think there is a problem if you snap ur timing belt in an rb (besides the obvious) - i mean it doesnt damage the rb engines - cant remember why but its basically the straight set-up of the engine - im sure that v engine setups will definately damage if the timing belt snaps though.
being a straight config engine doesnt mean its not going to die if the belt snaps, my beemer was a straight 6 and it was stuffed when the belt snapped
Bro mine had that sticker to, but had another one stuck over the top of it saying that my timing was done @ 93.xxx km's...i ripped it off, and got it done again. And sure enough it was bullsh!t...get ur timing checked man...as far as im concerned theyre not legit.
Edited by Sambo33gtst
RB's are not non compliance heads ... they
basically the "saftey" mechanism is the fact that a top Dead Centre the valves do not extend far enough to hit the piston - which is what causes the damage
RB's WILL bend valves if you timing belt snaps
that (sticker as said above) is for writing on with the KMs the car has done before its changed
so if you change it at 90,000 the first time, you should change before 190,000 next time
By the way my skyline has traveled according to the clock 107,000K's and still im yet to have it serviced. My funds are low and i have been quoted between $800 to $1000 for the magor 100,000K service. :laugh:
the 100000k service is considered by most workshops to be a full fluid bleed and change for your pwsteering. etc... along with changing your belts and water pump {hence the prices}. mention that you only want to do the belt and that should cut the price.. get the water pump changed if you can, coz u'll save on labour doin it with the belt.
dont risk the engine over a belt... engines cost more to fix
Edited by Scratch
wen i had my VL commo i was driving doin about 70km/h and car just stopped, we pushed it into the servo station just further down, where i kept crankin it over and over, still wouldnt start, got it towed bak home and found the timing belt tensioner bolt snapped and the belt off the cam gear, after replacing everything, car started right up again, no problems at all, nice and smooth.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
