  • Replies 113
Posted Images
I Just got my NEO dyno'd,
I got 179rwkw with a catback and apexi filter.
The heatsoak was pretty bad, the next run after that I only got 164.
From the mods you have it's possible.
Cheers
Josh
Yea exactly and mine was staying on 13 the whole time. The other guy was saying that if it was the fuel pump the AFR would keep rising... I don't see how tho
i think you are right there. i'd say its probably the fuel pressure regulator.
mayb i should just replace the FPR 1st and see if it fixes it
Should i be getting any particular brand or just get a stock1?
nismo ones are cheap and well tested .. and just fit inplace of the stock one easily
Depends on your long term goals.
If you don't plan to throw a highflow on it just grab another cheap (if they are cheap that is) stock item from a wreckers and try.
Otherwise.. grab a nismo item. They work well and are well priced. Grab one from nengun/perfectrun and the like.
You can't just throw a FPR onto a stock ECU. It'll mess up the fueling on anything but full throttle.
Also AFRs at 13 wouldn't be responsible for the high power. The power difference say between 12 and 13 might only be 2-5% max. 196rwkw at 8.5psi.. sounds like an RB30 haha.
what i find odd is that the AFRs are almost dead flat all the way through, even though it is lean
maybe its not actually a stock ECU? have you checked what it looks like for some kind of sticker? or opened it even?
Nah havent checked it, i jus assumed it was stock i guess. I'll do that this weekend and let u guys know. ECU is located under passenger side kick panel right?
yeah but if anything that would make the figures more realistic..
its when IT is way higher than AT that you see higher figures, so with the values around the same the computer won't apply much (any?) correction...
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
