Pauter's all the way, tad expensive, but sturdy ass hell. before assembling my engine i had them X rayed for micro cracing and machine quality, and the X ray dude was so surpised that he coulndt belive it that these would go in a car engine.
There's a few GT-Rs in Perth (including mine) running Pauter rods and they have all copped and survived a heap of abuse.
http://www.pauter.com/4340_rods.htm
When I win lotto and build my super responsive RB28, these are the ones I'll be using :P
http://www.pauter.com/titanium.htm
Its just a pic I found, They must of had the boost right up or the a/f ratios up to shit. :P
This looks like a bearing failure (bearing sized to crank) not a rod,no rod can stand that causing a bolt to break snaping the end of the rod.Note the rod bent a long way before cracking.About 1/2 the rods for sale look like the one in the pic so its hard to say what brand it is.
PAUTER is the best ive used.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
