Hey peoples
I own a Nissan R33 Skyline GTST with the rb25det.
if i use the following mods:
Apexi Power FC with HC
Z32 Air flow meter
Standard injectors that have been hi flowed to 780cc
Bosch 040 internal fuel pump
FMIC 600x300x100
Hybrid style intercooler piping kit 2.5"
Sard Fuel Pressure Reg
Blitz bov
Wat would be the best upgrade turbo that'll give me a lot more power but
will bolt directly into my engine. Whilst still spooling up quick, before 3500rpm
Stock manifold and dump must connect straight up.
Obviously wanting an internally gated turbo
Thinking along the lines of a Garrett GT30 500hp or something
If u could let me know my options and prices that'd be fantastic.
I'm wanting to purchase a new turbo within a couple weeks.
Just wanna make sure im getting wats best suited.
Regards.
Guesty
https://www.sau.com.au/forums/topic/136833-upgrade-queries/
High flow the standard turbo and they can handle around 450hp. With those kind of supporting mods, a moderate boost level and a decent yet safe tune you could see upwards of 350rwhp pretty comfortably without having to change a thing.
http://www.gcg.com.au/Catalogue_Menus/Upgr...pgrade_gtst.htm
Check out that link for further information, theres always a couple for sale second hand floating around the forums just keep your eye out.
https://www.sau.com.au/forums/topic/136833-upgrade-queries/#findComment-2542949
I like the idea of hi flowing, but for the money, wouldn't i be better off buying a new turbo.
Garrett, HKS etc. Something with a warranty etc? How do i know the hi flow wont fall to bits.
have been looking at slides hi flows, quite interested in those.
Cause spending $2000 for a gcg hi flow seems a bit stupid? doesn't it?
Thanks
https://www.sau.com.au/forums/topic/136833-upgrade-queries/#findComment-2543117
Thanks
When lots of people are using them with great results... doesnt seem stupid to me.
Shoot them an email and ask "whats involved" and i think you'll be surprised to find you pretty much get a new turbo, so its a smart move as it bolts onto the factory location and you'd never know it was there :D
https://www.sau.com.au/forums/topic/136833-upgrade-queries/#findComment-2543614
''HKS GT-RS can give good results if set up well. Its a direct bolt on nothing needs to be modified.
They can run upto 1.6 bar easily, A gold R33 not to long ago ran just over 300rwks on 1.4bar.''
And thizzle is also suposidly running similar kw's.
can anyone else read cameron's post? it's 5 above this one. Or am i more smashed than i think? mabey both! hehe
Edited by handyandy
https://www.sau.com.au/forums/topic/136833-upgrade-queries/#findComment-2543850
Hello,
GT-RS Turbo or GT2871R Turbo are priced around the $1450 Mark so High flowing your unit
at $2000 as stated is not a good idea.
And if you have not spent the money on all the items on your list above,
save the money and buy yourself a GTR32.
Just my two cents...
Cheers :D
Edited for crap grammer
https://www.sau.com.au/forums/topic/136833-upgrade-queries/#findComment-2543888
Handyandy,
Yes the turbo is rated at 400ps, as we all know HKS like to under rate thier products but it maybe possible.
Yes thizzle did get 300rwks but he does have a factory internal engine with bigger cams and the rest to suit.
I will let you know how we go with a GT-RS on a rebuilt engine, PFC & Z32 aswel.
https://www.sau.com.au/forums/topic/136833-upgrade-queries/#findComment-2544191
Hello,
Cheers ;)
Where can you buy a GTRS for $1450??? I'd line up for one! Thats good value or is this the HKS vs Garrett thing again?
https://www.sau.com.au/forums/topic/136833-upgrade-queries/#findComment-2544244
um a gt3040 is only 1800 new....make hp easier with wicked response from a .63 ex housing
thing is, when your in Melb... if the turbo doesnt look stock, it can end it pain.
Hence the GCG is a winner using the stock housings
https://www.sau.com.au/forums/topic/136833-upgrade-queries/#findComment-2544711
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
