i always thought that the flutter noise caused by VLs and other cars is because there is to much air being forced into the car but for no where to go after that?
After watching the HKS R34 on youtube in action i absolutely love the sound it makes. i never was a fan of the flutter but damn it sounds sexi. i urge anyone who loves or hates the sound to watch it.
http://www.youtube.com/watch?v=bRR_aisRgPI
my question is....if this is bad for the turbo...because the air is being forced back and around the exhaust/turbo.
why has HKS allowed this to happeN?
and its not just HKS.........
https://www.sau.com.au/forums/topic/136864-craziest-flutter-noise/
  • Replies 51
Posted Images
I have looked over that car in person in Japan and its modified beyond your wildest dreams anDru, its not some sick VL with a pod filter and intercooler.
i have the high performance imports mag review on the car and i know wats inside.
i jsut want to know why.....after so much modding there is still excess air not being released...or in short why is it still fluttering?
i swear if i could id make my car the exact same sound drooooooooolz
lol gotta love that drift king tchuchiya
"ish likes dish one"
Edited by anDru
sorry but im gonna have to quote u
Dont quote me here but i think the reason they dont put blow off valves on it is so that it has quick off-on throttle response.
Think about it, its HKS... do they care if their turbo dies?
but is that the only thing dat gets damaged....the turbo?.........nothign else?
oh and can someone tell me...the stock turbo on a r34 gtt. if i had no bov...compared to one that did.
how much faster are we guessing the turbo will die....if both cars are treated equally. (theres always someone who has to get smart and say shit like that)
Edited by anDru
Wouldnt recommend taking it off. Guess Nissan did put the blow off valve there for a reason.
Blocking it or taking it off will cause you to run rich, as in popping almost every gear change, and cause your car to frequently stall.
As for the life of a stock turbo, the wheel is ceramic. People's ceramic turbo's fail with blow off valves, so imagine without :|
Ive got a similar 'flutter' sound from my turbo!..talkin' to a guy at my local w'shop he said Ive a 'soft turbo'!! is this the same thing?? the explanation he gave me is much like whats been said already by the guys above...Im gonna keep it anyway sounds to good to lose :D
lol
* takes away andruu's thread making privlidges
yeah. coz inspecting the car in person, and reading about in HPI are totally the same :D
no its not the same but u get a preety rough idea of wat its got...compared to someone who just saw it on youtube......
:D
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
