mods/specs are:
rb20det
5spd
drift clutch
kkr430
jic coilo's
castor rods
steering spacers
rear camber arms
pinapples (the steel ones)
2way (unknown type, i suspect its nismo but ive never pulled it apart)
uras kit
more stuff i cbf writing
Edited by toffy
https://www.sau.com.au/forums/topic/137062-toffs-track-slurry/
  • Replies 108
Posted Images
  • 2 months later...
nice non da less :P
p:s this was inarks a31 before.... lol guessing u bough tit off him
cheers, yep it was niks :) , looks a lil different now eh?
ok three months on i dont no how da fk i new dat was inark's(nik's) ceffy :huh::O ... :P
anyway yea lukin different but still as nice :P:)
Edited by Dan_J
Lol all questions answered, it was a totally different car from the time nik owned it to the time i took it over to simon ;) , in memory all it had was the cat back hanging off it and the coilovers
ive got a small update, took the ceff on the track on the weekend, it seems to slide ok, needs some setup and tlc though :wave: . i burst a brake line which made things quite interesting :laugh:
now what you mean bout those brake lines had it happen to me at turn 1 mallala!!!... good time to invest in a 4spot 4stud upgrade :) with braided lines.
YES definately time for a brake upgrade, im gunna go 5 stud though.... and some braided lines :):)
  • 1 month later...
had a drift prac at symmons today...exit 3rd gear :( , i knew it was gunna go though, when i serviced it when i first got it the oil was metallic enough to paint a car :P . its getting a retune in a week and a half dr drift if i can find another gearbox in time :)
  • 1 month later...
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
