Today Nathan picked up the non hicas power steering lines and put them in today (much f**king around involved) :S
Tomorrow I have to buy an RB25 radiator hose and some other bits and pieces... but the
Engine is built and going in tomorrow!!!!!!!!!!!!!!!!!!!!1111111111
Edited by RB_turbo_bitch
  • Replies 160
Posted Images
Hey Tiff, good to hear its nearing completion, will be great to see what it turns out like. looks like ill be one of the chosen few to have a 20 still in their 32...... may have to change this...... keep us informed anyway.
WAR.
WAR.
Hey thanks Rick!
Hopefully catch up with ya soon hey? How's that front bar lookin? :no:
We didn't get to put the engine in today as planned... But we are one step away now!
Here's just a few pics from today!
wow yea! She's looking mighty fine now sitting so low!!
...and it's finally starting top look like an engine again!!
The manifold, turbo and dump pipe look hot as on there too!
..and yep she's ready to go now as you can see!
Everything is done now! I am so happy! :)
We fitted a new rear cradle into her last night.. (mine was farked and had hicas)..
...the finished project makes it all worth wile! ahhhhhhh
:D
I think over the past 6 months i have spend roughly 4000 and thats on everything.. not to mention i haven't gotten Nathan and kates labour bill yet!! :O
Watanabe's are off her now.. kate needs them for her ceffy.. so we just have some 32 m-spec wheels on the front and 32 gtr wheels on the back!
So far the engine feels very strong.. and i am very happy with the suspension and steering upgrades too!
Still running it in so dyno is still a little while away.. ;)
Does it drive like an s13 with that rack in it?
Congrats on the project
Yes it does a bit hey!
haha thanks! :D
looks great, good work! can't wait to share the same feelings when my timing belt arrives later this week and i get to crank over my backyard rb30det for the first time (assuming it works :)) ;)
Sweet! Good luck!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
