Bec's Birthday Bash - Sat 14 October
  • Replies 46
Huge thanks to everyone who came out on Saturday night.
Special mention to Chris and Daz for staying out till the wee hours on Sunday morning with me.
I had a ball!!! :laugh:
Things I remember:
* James designed his own hairdo
* Snowy is hilarious
* Brisby is a machine (but sometime machines break) :)
* Jaeger Bombs are more lethal than Wang Bangers
* Mavs drinking limit seems to be getting lower
* Taxis can be hard to find
* My feet still hurt
* I did spend alot of $$$, but I did not lose anything!
I had a ball!!! :rolleyes:
Things I remember:
* Brisby is a machine (but sometime machines break) :laugh:
Bec
Glad to hear u had a great night
PS http://www.poopy.org/v/pete/album/IMG_0881.JPG.html
I did finish both of those :laugh:
