Hi guys/girls,
As the topic title, and description states.
Im getting this ticking sound. when my car is idling. i found that its mostly when engine is warming up, but sometimes also while its warmed up. its not a knocking or a taping, its a 'ticking' sound, like a sensor or something, the sound is most hearable from underneth .
a friend of mine say, its from a exhaust leak. from knocking the exhaust on like a speed hump or something, which has created a small leak, which makes a sensor tick like that..? hMMmm?
Now before i spend $$$ getting it all pulled out, i was wondering. if anyone has had or knows of this issue, and the fix for it. and if there was a leak where would it be, and what would be ticking..
Thanks in advance. :)
Dale.
https://www.sau.com.au/forums/topic/138126-ticking-noise/
Sounds like lifters to me... what oil viscosity you using? mine does the same... a real light gentle "tick tick tick tick" on idle when cold and so do MANY other RB motors.. its heard right near the rocker cover... its normal
Cheers
https://www.sau.com.au/forums/topic/138126-ticking-noise/#findComment-2572162
Yeah ive got that aswell when cold mostly hear it mostly when you leave the car for a while then turn it on but as soon as you drive the car and its warm it quietens down. so its Lifters need to experiment with different oils until it goes away im still doing this.
https://www.sau.com.au/forums/topic/138126-ticking-noise/#findComment-2572800
Have you looked under the bonnet to see if you had left your watch in there? :)
Or maybe a mad bomber has left his package in there? :P:O
Now seriously, could be your bearing on your timing belt........get it checked.
When is the last time your timing belt was changed?And did they also change the bearings?
This can be a fatal problem(Engine...not you and the Bomb) :)
It can also be your lifters...in this case,don't worry... :ninja:
https://www.sau.com.au/forums/topic/138126-ticking-noise/#findComment-2575111
OK i have neglected my post :wave: busy with work.
OK its not a Tapping. ie. lifters or Other cam related .. its a Ticking. can hear it most from underneith the car. oil i use is Nulon 15-40 High Tech fast flowing. But i find it hard to believe its an oil related issue. though i could be wrong, ive built quite a few engines in my time, but I am new to this Import Scene so my ears are open to all suggestions.
Its weird it sounds like tick, exactly that. like and now it does it warmed up also, its Not loud, u cannot here it when ur cruising along, only really when ur stopped. can hear it most when ur in like an Undercover car park, or next to a wall , so the sound bounces from underneith the car to the wall, My brothers VLT also has a similar ticking sound, and both of us has Bumped our exhausts , but this could just be coinsidence of course.
https://www.sau.com.au/forums/topic/138126-ticking-noise/#findComment-2593085
Have you looked under the bonnet to see if you had left your watch in there? ;)
Or maybe a mad bomber has left his package in there? :wave::)
This can be a fatal problem(Engine...not you and the Bomb) :(
It can also be your lifters...in this case,don't worry... :)
The timing belt was just changed about 12k kms ago. apparently they did the bearings also. as it got a 100,000km service before i purchased the car, As i requested from the buyer. although u know u never know for sure what mechanics do unless u watch them, but the noise sounds like its comming from underneith the car, and No its not a Big end Knock or a Tappet TAP. its a Tick tick tick likea bomb .. but i havnt blown up yet ;)
https://www.sau.com.au/forums/topic/138126-ticking-noise/#findComment-2593096
how quick is the ticking?
another thing to check is the belts. make sure they aren't starting to fray.
Belts are perfectly new condition. and the Tick sounds is like tick, tick , tick, tick, 1 tick about half a second. Doesnt matter if i have it in neutral or in gear, when stationary can here it well. from underneith.
https://www.sau.com.au/forums/topic/138126-ticking-noise/#findComment-2593106
what u are hearing is most likely lifter / cam related. and its a TAPing isnt it. not a tick. check ur oils ur ising is correct. if that is ok . You may have worn components, u could fix this buy using slightly thicker oils, or buy replacing those components. and or adjusting them.. im not sure though if they cannot be adjusted. as well.. ive never had a look inside my engine yet :wave:)
https://www.sau.com.au/forums/topic/138126-ticking-noise/#findComment-2593114
Cheers
Yea well it was just doing it on warm up, But now it seems to be doing it hot also. But sometimes after a bit of a thrashing it goes away ?..
https://www.sau.com.au/forums/topic/138126-ticking-noise/#findComment-2593126
Mine only does it first thing in the morning. After letting the car warm up, then quick 5 min drive to work and I can here it after that.
Only time it does it....
Never after a long run or a thrashing.....
never even when it is warming up....
bugs the sh*t outta me!!!! :wave:
also even the slightest revs and it goes away
Edited by Jdfnq
https://www.sau.com.au/forums/topic/138126-ticking-noise/#findComment-2593206
bugs the sh*t outta me!!!! :dry:
yea sounds exactly the same issue im having.
https://www.sau.com.au/forums/topic/138126-ticking-noise/#findComment-2595402
injectors... mine does it too when cold also a little bit of lifter noise
yea my bros vl sounds like the injectors. but mine sounds louder from underneith than up at injectors..
no lifter noise on mine.. hmm
omg this tick tick tick sound is driving me crazy WEeEeeoOOO :dry::P
https://www.sau.com.au/forums/topic/138126-ticking-noise/#findComment-2595409
I hate to say it but my car does the same thing. Its an intermittent ticking on idle that dissappears around 12-1300 rpm. It absolutely shits me to tears and is not my thrust bearing as it is also making noises. So as long as i keep my foot on the clutch and have the engine 300rpm above idle everything sounds good.
https://www.sau.com.au/forums/topic/138126-ticking-noise/#findComment-2595888
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
