guys, ive been searching for results but nothing!
how about creating one of those results register threads, just like in the turbo section.
if everyone can list their results, wat engine, modifications and maybe dyno graph.
i think itd be good to look for ideas to do to our na engines. i plan on puting a rb25de in my r31, and i want to know power people are getting :/
i might as well start, but its nothign special :)
rb30e, extractors, rear muff gone, auto. 85rwkw. almost too much power :sick:
*Good Idea, sorry to edit your thread*
Eveyone Please put results only No chit chats- Please edit your comments like one below
eg.
Model - R34 R33 R32 R31 R30...etc
Engine - RB20DE RB25DE RB26DE...etc
Modifications - Intake system Extractors...etc
Dyno tune results...etc @ what RPM...etc
MISC -other infomaitons
Thank you all
Glue :kiss:
Edited by Pva_Glue
https://www.sau.com.au/forums/topic/138169-na-power-results-all-na-engines/
  • 4 weeks later...
r31 skyline
rb30e
3-2-1 exstractors 2.25" exhaust with a very restrictive muffler.
chip. adv timeing, k&n pod plus CAI
unknown power figure but around 110rwkw.
last runs was 90 rwkw with only exhaust shity pod
done a 16.3 @83mph at calder drag strip.
  • 3 weeks later...
Model: R33 series 1 GTS25 sedan
Engine: RB25DE
Mods: converted to manual, K&N pod filter, 3" custom intake pipe, CIA, extractors 6,2,1 heat wrapped, 2 1/8" exhaust cat removed, GTS link ecu
Power: 117rwkw
  • Like 1
Engine: RB25DE
2 door Coupe
GT-4
92.5kw (on all 4 wheels) @ 5814rpm
831.6Nm @ 4325rpm
mods: pipercross panel filter, 2.5" catback exhaust
this is going to be my baseline for modding my car, at least I know how much it pulls now..
any suggestion which other mod I should do next? pm me.. don't reply here =)
Edited by HolyEvil
  • 1 month later...
Model: 1987 R31 Skyline Ti
Engine: RB30DE with VVT
Modifications: Extractors, exhaust, twin tb, safc untuned, billet f/wheel, reground surecams, 10.5 compression, 18 degrees timing, 98ron ultimate
Power: 150.9RWKW @ 172kmph an 507nm (374FtLb) torque at 144kmph
with more left in it, she's an economical daily but rich and restricted above 5000rpm so once thats tuned/fixed i'll be a happy camper
  • Like 1
very impressive skit. what 1/4 mile times are you running? i expect low to mid 14s?
model: r33 gts25
engine: rb25de
dyno dynamics
modifications: custom air intake, pod filter
power: 108.4rwkw
dyno logistics
modifications: back to standard panel filter, coby extractors, 2.5" cat and 2.5" cat back exhaust.
power: 101rwkw
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
