Timing Belt Replacement
ezzaNrod
 Share
Hey peoples!
Our timing belt went on the weekend! We have the new belt, were not sure if it has done any further damage? hopefully not ! Does anyone have any idea how to put it back on and in the right spots after its snapped? We have asked a few machanics in town and no one wants anything to do with our car??
Any ideas would be greatly appreciated! its only just got back on the road after the yellow sticker and now this??!!! ahhh
anyway, anything would help.... its a R33 95 GTST
cheers !
go to a workshop. hyperdrive should be happy to help
if u f**ked it up bye bye engine
they are in geraldton :P
theres a guy at tyrepower in geraldton that owns a white 33, maybe ask him where he gets his car serviced?
Don't screw with it because it is a very important part of the engine! I got mine done at a workshop which will remain un-named, one different to where my performance mods are done, and for that reason I believe they didn't take the care they should have with it. Timing was way out when I got it back, and it made it hell.
Take it to somewhere that has dealt with your car/previous cars before & you can trust. If that doesn't apply, somewhere convenient for you.
DIY I say - I did mine, with a bit of common sense and a willingness to learn its pretty simple :P
Absolutely!!
I have done numerous RB timing belts and a few others. The Gates belts have lines on the. If you point the dowels on the cams up and set the bottom end to TDC then line up the belt marks with the punch marks.
Of course its VERY important not to turn the bottom end independent of the cams, otherwise the valves will hit the piston tops and bend, if that hasnt already happened. The way around this, remove the cams so the valves arent depressed, easy.
Brent.
Brent.
I lined up my cams to the marks on the timing cover, THEN turned the bottom end over 39849384 times to make it all line up with TDC, worked fine for me. I can only assume by this logic that keeping the cams on thier marks, keeps them totally clear of the pistons??
P.S. Yes, my engine is fine :laugh:
 Share
    • He could just take the Bogan Cruise Ships setup... Already got a good setup, with blower, the auto was rebuilt too wasn't it? Perfect time for him to upgrade the tailshaft, diff, and axles...    And wouldn't need to waste money on redoing the Commos seats, as he could just buy race seats for the 5...   As a highly modded car he could avoid the ability to give it away to offspring too when they crash their cars...
    • It's really interesting how much it's moving left to right, and doesn't appear to be actually spreading. For this to be moving left to right, without flaring, means unequal forces being applied until equilibrium hits in one way or another.   Reasons it could be unequal; Piston sizes left to right are different sizes. Only minute differences. Pistons moving on different planes. That is, are they moving directly straight at each other, or slightly out of alignment. The fluid is restricted getting to one side.   Some tests you could do. Pull the bleeders on the left and right, fit each side with pressure gauges. It will allow you to make sure pressure is equal (and really, it should be as fluid flow is so damn low, so fluid flow dynamics shouldn't come into it).   With the calipers off the car, have both sides retracted as far as possible, measure very very accurately (think micrometre) distances between opposing pistons in four different spots per set of pistons. Firstly, on each opposing pistons pair, the measures on for different spots should be equal. If it's not, and especially if one spot appears to actually get closer compared to another, the pistons aren't aligned, and now the forces left to right won't be equal, as they're the forces fighting each other.   You can also pull all the pistons out, and very very accurately measure the diameter of them. If they're not equal left to ight in the pairings, and especially if the area of the pistons on one side is different to the area on the other overall, it'll all be out of whack.   My bet, is shit QC in making sure the pistons move in the same plane left vs right. Some minor out of square machining, and nothing will line up, things will want to move around.
    • Whilst putting a V8 in a MX5 would be fun, it would negate the whole cheap to run fun daily that the MX5 will be used for If I wanted a faster little convertible I would have got a engine check light, I mean a BMW Z4 M, but going off the issues that the guy at work who recently got one is having, it is lucky I didn't  Meh, horses for courses, the Bogan Cruise Ship is my go to for some horse torques
    • I reckon give him a few months, LSX swap would be good
    • Mark needs to get bored at work and order things on here...
