Hello all..........
After the ,what song you would loose your license to?
I have a new one for you........as Topic suggests.
Name the road ,you are most likely going to loose your license on?
I will start with the ramp on the Western-ring Road headed out of town from Greenbourough.
This is the new Bridge that goes out to Cooper Street.
The bridge which goes over the Road is an 80KM Zone :P .I have not seen any-one doing that.
So post ,
STREET?
AREA?
WHICH DIRECTION YOU ARE TRAVELLING IN?
SPEED INDICATED ON ROAD?
Please do not post times and cars your driving ...just in case :O:):)
https://www.sau.com.au/forums/topic/138274-best-road-in-melbourne/
  • Replies 46
kings way westgate freeway exit...
such a great sweeping bend
80km on pirelli P6000
100km on dunlop sport 300e
120 on nexen 2000
105 on falken somethings
go the bluebird
better yet scobie rd up near shepp..
nearest intersection 3km
viewable distance....more than the cop radars
subaru brumby 150
volvo 740 170km
TM magna 180km
Bluebird pegged off the speedo at 200km
eastern freeway. both ways. i've never seen anyone do under 105km.
ill be on it 2morro in my ferrari 355 spider (silver) at 11:30am....catch me if you can
Hope you are not setting up some-one ? :P:O
start of the western ring road from Greensborough...I come from the diamon creek way.
I love to get in the outside lane and cain it past everyone...
I think it its 80kmph
also my other dialy fav.
The hoddle street ramp to the eastern fwy...
The camber is all f*ked up but my FTO handles it very sweet. I cain it around there and hit 8k. before th bridge
In the r33 its more fun. I stay on the outside lane and merge right...I try to see what is the fastest speed I can do at the bridge if there are not cars...the bridge comes up fast...you I don't end up going that fast...l
isnt there cameras on the eastern now?
I remember back in the good 'ol days (like 2002).. when 130 was a common speed..
When the hume fwy wasn't complete.. gunning it from cooper st onto the freeway was fun.. but now you have to watch out for trucks.. not alot of time to merge/judge their speed :laugh:
I think any freeway entrance is fun.. esp onto the ring rd.. about the only place you can put your foot down without getting a speeding fine...
:laugh: that is, no shit, the best fun you can have in Greensborough
If you we inclined to break the speed limit around my area it would be on Doncaster rd heading up towards Shoppo.
Since they extended the freeway, the traffic that goes up that hill is minimal at the best of times and you can weave your way up the hill in all three lanes at practically any speed you like... but that would be bad and you shouldnt speed mmmkay
yeah onramp to ring road at greensy end is 90kmh ... thn at plenty road becomes 100.. but cops sit in the break where the onramp and off ramp at the greensborough end splits, so you cant see them until its too late
I agree with that, that road from the western to the footbridge is fantastic, although after that is gets a bit bumpy and the joins in the onramp combined with coilovers = all bad....also the western between hume hwy exit and the above bridge greensborough bound....long flat and wide
Anyplace that has a tunnel - i get excited by the sound of a loud exhaust, just cant help myself.
Try the Punt Rd ramp on to the Monash outbound beneath the silo's! Surrounded by close walls, the acoustics are sweet!!!!
Thats funny....when I :D see a tunnel I normally avoid it cause I am married...... :P
But yeah nothing beats a good squirt in an enclosed area....city would be great early in the morning.
I would love to open it up on Collins street. :(
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
