  • 4 weeks later...
  • 1 month later...
just to let any one know that is getting there car resprayed or any aftermarket parts: r33 series 2, the 1995 tll 1996 comes in spark silver metalic, but the 1996 till 1997 is in sonic silver./.
i made the mistake of saying spark silver for my gtr wing, but turned out my car was a 1996 till 1997 (which is like late 1996 and it was sonic silver :D. ooops.. just for others who try it .. :)
hey my car is also 96 GTST, I presume same colour as yours (silver), can we buy any paint from nissan with this oclour code like touch up paint?
Phantom32
there is no code for it, TOP SECRET japan makes this and will not give out their code. it can be bought for some stupid amount like $600 a litre from them directly.
but im sure there are plenty of places that could mix up something similar, but would be hard to get exact.
  • 1 month later...
  • 3 weeks later...
What is the paint code for V35 blue? (
Unsure, ill try and find out
Is the R34 GTT silver code there? The titanium grey type colour?
Just not sure which one it is...
It would be there, but yeah not sure which one either. Someone with a grey r34 help us out?
  • 1 month later...
  • 1 month later...
Anyone know whether the Millennium Jade for the BNR 34 has any pearl elements inside? Or by just giving the colour code (JW0) to the paint-shop and the mixer will know just how much is required?
A friend of mine had the actual R34GTR Nur Spec with that colour, i do see a slight goldish pearl colour when certain light reflect on it.
Pls advice...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
