Sketch the sort of cage you want, noting any diagonal bars and i will get you a price.
Big problem with the comprehensive cages with side intrusion etc is that they are expensive to fabricate and install as they require cutting of the dash, mods to door trim etc. Big job and associated cost
The side intrusions being bolt in is not a problem, and basically as far as welding goes I want it welded to the A-pillar ad tied to the B-pillar. I want it to be a weld in cage, but don't mind some of it being bolt in if you know what I mean?
Ok here is the email address of the gent that i brought my 7 point cage from
Sukhbir Singh [[email protected]]
And i have to say the cage was quality and was a perfect fit. Bit of a bugga to fit through the dash but i didnt really worry to much as it is a track car.
And whats ricer about a cusco cage for safety! not sure where that remark comes from.
I enquired about getting bolt in and weld in cages a while ago. The bolt in cages were around $300 more due to the extra work involved. For a weld in 6 point with rear cross brace it was around $2500 for the 32 gtr. I had a quote for around $2k by another place but later found out that thier cage had issues with welds when it came to getting it approved.
As for jap bolt in cages I spoke to the wrx day guy who can be nice or nasty. Can't remember his name but you know who I mean. He said he had no issues with me using a non-approved jap cage as long as it wasn't dodgy.
For the cost involved in a a full cage it isn't really much if you plan on keeping the car for a while vs being dead or paralized.
phunky monkey that is 99% the same design as the cage in my race car, my diagonal is between the B pillars instead of B and C. And of course all joints are welded no bolts.
Welded cage does not require any bolts, just needs windscreen and dash out so you can get the main hoop and front arms in to the car...then weld it in place.
For the 3 cages we have done so far, 1800 is the most we have paid, so shop aruond. Anyone can build a cage as long as they follow the CAMS requirements.
Thanks for that Tacker. I take it that is the Dubai distributor?
Gareth: Thanks for that mate. I think you're referring to Wayne? Good to know that he will accept it.
Duncan: For around $1800-2000 makes it seem a lot more reasonable to go the weld in CAMS approved route. I'm just very wary of who I would get to do my work as I've recently had a friend of mine pay big bucks to receive a very dodgy cage, and as a result is having to get it made again. But obviously with the pricing you've given it really will pay to shop around, so I'll see what I can find out. Thanks.
Dane
CAMS/FIA spec cage in my last car cost me $1500 with double diagonals, double intrusion bars, diagonal in the roof section, and braces in the door openings. main hoop is tagged to the B pillars, front legs are welded to the A pillars (you might be able to make out the reflection in the windscreen.
LOL, is that the 1200 :laugh: Lifes hard decisions. To play with a Mk 1 Escort or a 1200 Coupe :)
Dane, when speaking to places it will pay to mention to them that you are not log booking your car (or are you) Inspection etc of the cage does add expense. So will the added complication of fitting the cage to a more modern car like a 180SX.
Good bet is to gut your interior and get them to install the cage, Then you can come along and paint it and install the interior with the extra attention to trimming dash that only the owner ever bothers with
I have just purchased a CAMS spec cage from Bond roll bars for my VH Commondore.
6 point CAMS spec steel tube
bolt in $880 (includes joiners etc)
weld in $800 (includes intrusion bars)
http://www.malvern-group.com.au/
Bond roll bars (NSW), Browne Davis Automotive (Vic), Malvern Motorsport (Vic), Fabraications (Vic) all can do excellent cages.
Well Malvern just completly stuffed a car that is well known to the Vic people eh Dane? :)
So personally im not very trusting of the workmanship.
If it means spending a couple extra bob to get a job right the first time...
$800 is just filthy cheap though
On that, just because one place says its hopeless doesnt make it so. The cagse probably does have problems...probably. But again, if the particular employee who did the cage has left then you wouldnt expect the next one to be as bad?!?!?!?
That said i wouldnt use anyone but Brown Davis myself
would u have a pic of the joiners? I emailed Bond and they never replied... do they still use those ones that look like theyre part of a fence post? :laugh:
Bris: Yeah, I would like to get it log booked incase I decide to move the car over to race rego if I get defected, so I'd like to have it if possible.
I would strip it myself too, there's not that much to them, and I've been meaning to strip the rear properly, but wanted to wait until I can get it painted at the same time.
VHR32: $800?? That's ridiculously cheap! I'll give them a call and see if they have a template for an S13 already and see what they say. Thanks mate.
Ash: I'm not impressed by the way it's been handled either, so yeah, I won't be using said workshop. :)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
